how to use global variables in asm
hi
I am trying to use global variable as follows in the asm. it throws error as undefined symbol.
.global test
.global result
ldr r0, resultadd
;str ;as required
resultadd   .word    result
i have not done extern to c file yet because asm itself is throwing error. I have seen other post int he community but somehow this doesnt work for me.
Request for help
Chitra
  • Hi Chitra,
    The assembler is looking for an actual definition of the symbol "result". This needs to be explicitly defined either in this file or another file in which it is declared as a global variable.
    For example, you could add the following line in your asm code:
    result    .word    0x08000000
    Regards, Sunil
