Other Parts Discussed in Thread: TM4C123GH6PGE
Im develop Tiva Microcontroller with Ti-RTOS. Can you share for me an example code or how to read write data with EEPROM in TI-RTOS.
My current Tiva is TM4C123GH6PGE.
Thank you so much.
Thank you so much.
Aut,
What kind of EEPROM are you attempting to communicate with? Does it have a serial or parallel interface? We have a plethora of example code for using our Tivaware libraries to facilitate communication over SPI, I2C, GPIO bit banging, CAN... a very wide range of interfaces. Without knowing what type of interface you are using to talk to the EEPROM, though, I don't know which peripheral you're going to need to use.
Check out the examples/peripherals directory of your Tivaware installation directory (by default, C:/ti/TivaWare_C_Series-1.0|1). Odds are, you'll be able to find an example of whatever peripheral your EEPROM talks over in that directory.
Hi Jordan,
I use 2k internal EEPROM of chip.
I try with C:\ti\tirtos_1_10_00_23\products\TivaWare_C_Series-1.0\driverlib\ eeprom driver but it not work.
