Other Parts Discussed in Thread: TM4C1231H6PZ
Now i want to use can module in tm4c1231h6pz
But the cantx pin has no output,
The following is my code:
PF0 is a special pin - this class MCUs - and requires "unlocking" prior to your attempted use as CAN. MCU manual - GPIO section - details and describes this unlock process. Realize that PF0 is your potential CAN_RX.
You, "CANIntRegister()" - but the commentary advises that this should be reserved for "dynamic vector table allocation." Suggest that you use far more normal/customary static allocation - making use of the start-up file's interrupt vector table. (many, many examples detail)
You report that CAN_TX is silent - yet we find no, "direction to transmit" anywhere w/in your short code listing...
Suggest that you re-visit Examples\Peripherals\CAN\simpleTX (and simpleRX) for needed, further detail.
