TMS570LS2124 Minimum supply current from 1.2 volts
Sirs,
Could you please tell me the minimum supply current which the part draws from a 1.2 volt supply ?
The information was not found from the "ICC, ICCPLL" in the elec. specification of the DS (SPNS165a).
The value would be the sum of the core and the PLL currents. And the situation of the minimum current would be the reset state.
As a background, my 1.2V supply is tricky in light load. Therefore I'd like to put a bleed resistor if the minimum current is too small.
Hideaki Nambu
