uVision: How set up an .ini file for debugging?
I want debug my program from the internal SRAM. There for I need an initialisation-file (.ini) for the debugger. Unfortunately I wasn't able to find a documentation how to write such a file.
I'm using a stellaris launchpad (LM4F120H5QR now TM4C123) and a ULINK2 debugger.
Does anybody know, how to set up the .ini file or can provide a link or a documentation concerning the topic?
Regards Jannis
        Perhaps, are you referring to the startup file? From what I read the .ini file for Keil Uvision is a debugger script file.
    -kel
    i think I my question isn't as clear as it should be.
    I'm looking for the debugger script file which configurates the processor before runnig my aplication
    This method is also used in a example with the STM32F4 Discovery.
    http://www.keil.com/appnotes/files/apnt_230.pdf page 5
    Regards Jannis
    Your question is specific to Keil tools - so the their documentation must reveal this. I searched the Keil site and found this:
    http://www.keil.com/support/docs/3156.htm
    Please note also it is not mandatory to use this file, although may help you. Read the TI's document below which shows how to manage a Keil project:
    http://www.ti.com/lit/ml/spmu355/spmu355.pdf
    Petrei
