TM4C129x Ethernet bootloader runs into NMI handler
Hello e2e,
Our customer is using TM4C129x in PLC project, now they are doing the Ethernet bootloader application, using TivaWare 2.0 ethernet bootloader example.
the IDE is IAR compiler, the compiling is ok, but MCU will run into NMI handler while debugging, attached is the project, could you pls help to have a review?
thanks.
LEON
6131.oldtest.zip
