Other Parts Discussed in Thread: HALCOGEN
Recently we started evaluating TI's Hercules line as it seems to be a good platform to start developing the next generation of our automotive application. We found that configuring the device peripherals can be challenging compared to our current ARM7 platform. That is where HalGoGen makes our lives easier. The problem we have is that our toolchain (IAR) requires certain functions and symbols to be encapsulated ( extern "C" { } ) when using C++. Once HalCoGen generated the initialization code we can look for all the symbols requiring this, and encapsulate them manually, it is not the ideal solution but it works. The problem comes when we need to change some peripheral's configuration, HalCoGen deletes all of our user added lines, or if our user added lines were enclosed within the user code blocks, HalCoGen generates new user code blocks and breaks everything irreparably and we have to start all over again.
Is there some workaround for this? Does HalCoGen has some kind of built-in support for IAR's C++?
