EMIF address and data on same bus
I'm looking at x8 parallel memories that use a bidirectional bus for address, data and commands. There are GPIOs used to latch desired behavior ( ALE, CLE, WE, RE etc. ). One example of this kind of memory is Spansion S34ML08G1. It is a NAND flash.
Now, I'd like to see if it's possible to use the EMIF controller on the Hercules. I don't want to manage the gpios manually to access the memory. From what I see, EMIF has address lines and data lines. I know that the technical manual only refers to SDRAM and async NOR but I'm wondering if there's another mode that could fit my needs.
Thanks!
