Other Parts Discussed in Thread: HALCOGEN
I'm working with a RM48HDK. The attached project is a multiple PWM example mainly following the HalCoGen included example but with 7 PWM for each HET. I've performed the same settings for both HET1 and HET2. The HET pins does not emit nothing. If I disable the HET2 driver in HalCoGen the HET1 starts to work as expected.
Do HalCoGen has some problems or known bug with HET2 PWM?
Thank you
