Other Parts Discussed in Thread: TMS570LS3137
What is the value of internal pullup resistor available in I2C module of TMS570LS3137?
Is this value common for other I/Os also?
Shihab
Shihab
Shihab said:What is the value of internal pullup resistor available in I2C module of TMS570LS3137?
The value of the internal pullup and pulldowns are indicated in the Terminal Functions section 2.3 of the datasheet (data manual). Specifically for the I2C interface, you will find this information in Table 2-8 of section 2.3.1.8. The value is 20uA pullup.
Shihab said:Is this value common for other I/Os also?
The specific values, if relevant, is found in similar tables in Section 2.3 of the datasheet. Choices are 20uA and 100uA (both nominal values). The range for Iil and Iih are found in Section 3.6. entitled Input/Output Electrical Characteristics Over Recommended Operating Conditions.
