Other Parts Discussed in Thread: HALCOGEN, RM46L852, UNIFLASH
We have a custom board with the RM46L852 and are using the latest CCS and Halcogen. Also using Spectrum Digital XDS200 emulator.
After bringing up the second revision of this board, everything worked fine. Then we somehow set the PLL frequency above the maximum 220mhz. Now, the emulator won't connect, instead giving an error saying it can't write to certain memory segments and to verify linker command/map files.
Also, trying to erase device using UniFlash gives us an error/abort.
We have the first revision of our board, and everything works ok with CCS and UniFlash.
So, my question is, can the RM46 be permanently damaged by improper settings?
