Hello Support,
For GIO Port Pin in OUTPUT Mode, GIODIN Register shows the pin status and will it be same as GIODOUT Register contents?
I thought it will be same between GIODIN as well as GIODOUT when the corresponding PIN is in OUTPUT Mode within GIODIR. But if you see the picture, for Bit 1 it is not so. Can you please explain what am I doing wrong?
Thank you.
Pashan
