Cannot open source file - CC3000SDK
Hi all,
I am very much new to CCS compiler..... when i imported Wifi application source code from tivaware and build it .... i received following errors....
please somebody help me with this...
i am using CCS5.5.0.
**** Build of configuration Debug for project Basic Wifi Application ****
"C:\\ti\\ccsv5\\utils\\bin\\gmake" -k all
'Building file: C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/Basic Wifi Application/basic_wifi_application.c'
'Invoking: TMS470 Compiler'
"C:/ti/ccsv5/tools/compiler/arm_5.1/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O2 -g --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/StellarisWare" --include_path="C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/inc" --include_path="C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Basic WiFi Application CCS/Basic Wifi Application" --include_path="C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/CC3000 Spi" --include_path="C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/CC3000HostDriver" --include_path="C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/HyperTerminal Driver" --gcc --define=ccs --define=__CCS__ --define=PART_LM4F232H5QD --diag_warning=225 --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="basic_wifi_application.pp" "C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/Basic Wifi Application/basic_wifi_application.c"
"C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/HyperTerminal Driver/dispatcher.h", line 43: fatal error: cannot open source file "inc/hw_ints.h"
1 catastrophic error detected in the compilation of "C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/Basic Wifi Application/basic_wifi_application.c".
Compilation terminated.
>> Compilation failure
gmake: *** [basic_wifi_application.obj] Error 1
'Building file: C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/Basic Wifi Application/board.c'
"C:/ti/ccsv5/tools/compiler/arm_5.1.1/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O2 -g --include_path="C:/ti/ccsv5/tools/compiler/arm_5.1.1/include" --include_path="C:/StellarisWare" --include_path="C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/inc" --include_path="C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Basic WiFi Application CCS/Basic Wifi Application" --include_path="C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/CC3000 Spi" --include_path="C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/CC3000HostDriver" --include_path="C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/HyperTerminal Driver" --gcc --define=ccs --define=__CCS__ --define=PART_LM4F232H5QD --diag_warning=225 --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="board.pp" "C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/Basic Wifi Application/board.c"
"C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/Basic Wifi Application/board.c", line 47: fatal error: cannot open source file "inc/hw_types.h"
1 catastrophic error detected in the compilation of "C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Source/Basic Wifi Application/board.c".
>> Compilation failure
gmake: *** [board.obj] Error 1
gmake: *** No rule to make target `C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Basic WiFi Application CCS/CC3000 Spi/Debug/CC3000 Spi.lib', needed by `Basic Wifi Application.out'.
gmake: *** No rule to make target `C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Basic WiFi Application CCS/CC3000HostDriver/Debug/CC3000HostDriver.lib', needed by `Basic Wifi Application.out'.
gmake: *** No rule to make target `C:/ti/CC3000SDK/CC3000 SDK/LM4F232H5QD/Basic WiFi Application/Basic WiFi Source/Basic WiFi Application CCS/HyperTerminal Driver/Debug/HyperTerminal Driver.lib', needed by `Basic Wifi Application.out'.
gmake: *** No rule to make target `C:/StellarisWare/driverlib/ccs-cm4f/Debug/driverlib-cm4f.lib', needed by `Basic Wifi Application.out'.
gmake: Target `all' not remade because of errors.
**** Build Finished ****
  • From these errors, it looks to me as if you probably downloaded the CC3000 software that is distributed via the CC3000 Wiki? This has known problems. We spent a lot of time recently porting this into TivaWare 2.1 to avoid these issues. Please try importing the projects from the examples/boards/ek-tm4c123gxl-boost-cc3000 (if using a Tiva TM4C123 LaunchPad with the CC3000 Boosterpack) or examples/boards/ek-tm4c129xl-boost-cc3000 (if using a Tiva TM4C129 Connected Launchpad and CC3000 Boosterpack) and build those.  We tested this here before the release and it worked correctly.
  • Thank you for the reply sir...
    I will try out what you have suggested.
    Bharath
