NHET2 prescalers and program size
I'm working with a RM48HDK.
Do a four instruction HET program can be executed with a lr prescaler 2 (==4 cycles) or the HET need some more time slot to restart?
I have a simple multi-pwm program made of 4 instruction:
L00 CNT {next=L01,reg=A,max=32}
L01 MCMP {next=L02, en_pin_action=ON,pin=1,order=REG_GE_DATA,action=PULSEHI,data=8}
L02 MCPM {next=L03, en_pin_action=ON,pin=5,order=REG_GE_DATA,action=PULSEHI,data=16}
L03 MCMP {next=L00, en_pin_action=ON,pin=13,order=REG_GE_DATA,action=PULSEHI,data=24}
that should require only 4 cycle but setting the lr to 2 (==4 cycle) seems to disable the fourth instruction (i don't see the pwm on the pin 13).
Thank you
