Problem with Keil + PWM at EK-TM4C123GXL LaunchPad
Other Parts Discussed in Thread: EK-TM4C123GXL, TM4C123GH6PM, TM4C1231C3PM, LMFLASHPROGRAMMER
Hi!
I'm stucked programming with Keil environment as I didn't find any PWM example code for the EK-TM4C123GXL LaunchPad board.
I found some interesting code for Code Composer Studio (CSS) but I can't use it in Keil, could you give me some tips to do so?
Specifically it's about this Labs at TM4C123G_LaunchPad_Workshop:
http://processors.wiki.ti.com/index.php/Getting_Started_with_the_TIVA%E2%84%A2_C_Series_TM4C123G_LaunchPad
and the labs that are inside:
http://software-dl.ti.com/trainingTTO/trainingTTO_public_sw/GSW-TM4C123G-LaunchPad/TM4C123GLaunchPadWorkshopSetup.exe
I'm trying to use the PWM code in Keil but I can't use it.
Even better if you have code to run a PWM module in the EK-TM4C123GXL LaunchPad board.
Thanks!
P.S.: after searching several days in Internet for a solution for PWM module at a EK-TM4C123GXL LaunchPad board I didn't find any solution for Keil, so I think it needs a proper and good solution.
