Hi all, I´m trying to use safertos_demo to create an application that allows to run two task, the first one has to toggle a LED (when some condition active it, aperiodic task), the second one is a periodic task that read analog value and write the UART port, when it reads (analog data from ADC), it writes the data in UART port (periodic task), I´m trying to execute two task like periodic (LED and UART), and then, change (is as should be) LED periodic task into aperiodic task. I can do the analog reading using ADC and write it in UART port without safeRTOS, when I add the safeRTO the software donesn´t do anything. My code is attached.
// led_task.c - A simple flashing LED task.
// Copyright (c) 2009-2011 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 8049 of the DK-LM3S9D96 Firmware Package.
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/gpio.h"
#include "driverlib/rom.h"
#include "SafeRTOS/SafeRTOS_API.h"
#include "idle_task.h"
#include "led_task.h"
#include "priorities.h"
// The stack for the LED toggle task.
static unsigned long g_pulLEDTaskStack[128];
// The amount of time to delay between toggles of the LED.
unsigned long g_ulLEDDelay = 500;
// This task simply toggles the user LED at a 1 Hz rate.
static void
LEDTask(void *pvParameters)
portTickType ulLastTime;
// Get the current tick count.
ulLastTime = xTaskGetTickCount();
// Loop forever.
while(1)
// Turn on the user LED.
ROM_GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3, GPIO_PIN_3);
// Wait for the required amount of time.
xTaskDelayUntil(&ulLastTime, g_ulLEDDelay);
// Turn off the user LED.
ROM_GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3, 0);
// Initializes the LED task.
unsigned long
LEDTaskInit(void)
// Initialize the GPIO used to drive the user LED.
ROM_GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_3);
// Create the LED task.
if(xTaskCreate(LEDTask, (signed portCHAR *)"LED",
(signed portCHAR *)g_pulLEDTaskStack,
sizeof(g_pulLEDTaskStack), NULL, PRIORITY_LED_TASK,
NULL) != pdPASS)
return(1);
TaskCreated();
// Success.
return(0);
// uart_task.c - Task to output text on the UART.
// Copyright (c) 2009 Texas Instruments Incorporated. All rights reserved.
// TI Information - Selective Disclosure
#include "utils/uartstdio.h"
#include "uart_task.h"
#include "inc/hw_nvic.h"
#include "inc/hw_ints.h"
#include "grlib/grlib.h"
#include "drivers/kitronix320x240x16_ssd2119_8bit.h"
#include "drivers/set_pinout.h"
#include "driverlib/uart.h"
#include "driverlib/adc.h"
#include "driverlib/interrupt.h"
#include "driverlib/sysctl.h"
#include "driverlib/debug.h"
#include "display_task.h"
#include "stdio.h"
// This task receives messages from the other tasks and outputs strings to the
// UART.
// Variables globales para la aplicaci�n.
float humedad, temperatura, datoSensor, Humedad1;
char humidity[30];
char temperature[30];
char datoS[30];
unsigned long ulValue=0;
unsigned char prueba;
static void
UARTTask(void *pvParameters)
// Set the clocking to run directly from the crystal.
ROM_SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
SYSCTL_XTAL_16MHZ);
// Set the device pinout appropriately for this board.
PinoutSet();
//configure PB4 for analog measurement
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
GPIOPinTypeADC(GPIO_PORTB_BASE, GPIO_PIN_4);
SysCtlADCSpeedSet(SYSCTL_ADCSPEED_125KSPS);
ADCSequenceConfigure(ADC0_BASE,0, ADC_TRIGGER_PROCESSOR,0);
ADCSequenceStepConfigure(ADC_BASE, 0, 0, ADC_CTL_CH10 | ADC_CTL_IE | ADC_CTL_END);
ADCIntClear(ADC0_BASE, 0);//borro la interrupci�n de secuencia
ADCSequenceEnable(ADC0_BASE, 0);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
// Enable processor interrupts.
IntMasterEnable();
// Set GPIO A0 and A1 as UART pins.
ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
// Configure the UART for 115,200, 8-N-1 operation.
ROM_UARTConfigSetExpClk(UART0_BASE, ROM_SysCtlClockGet(), 115200,
(UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |
UART_CONFIG_PAR_NONE));
// Enable the UART interrupt.
ROM_IntEnable(INT_UART0);
ROM_UARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT);
while(1){
ADCProcessorTrigger(ADC0_BASE, 0);
while(!ADCIntStatus(ADC0_BASE, 0,false)){
//Espero a que la conversi�n est� lista
ADCSequenceDataGet(ADC0_BASE, 0, &ulValue);//Guardo los datos en el buffer &ulValue
datoSensor = (float)ulValue;
ulValue=ulValue*255/1023;
prueba=ulValue;
//prueba = 0x11;
ROM_UARTCharPutNonBlocking(UART0_BASE, prueba);
// Initializes the UART task.
unsigned long
UARTTaskInit(void)
// Create the UART task.
if(xTaskCreate(UARTTask, (signed portCHAR *)"UART",
(signed portCHAR *)UART0_BASE,
sizeof(UART0_BASE), NULL, PRIORITY_UART_TASK,// LA PRIORIDAD DE LA UART ES 0
NULL) != pdPASS)
return(1);
TaskCreated();
// Success.
return(0);
