Other Parts Discussed in Thread: UNIFLASH, ENERGIA
Hai every one.
i have tiva launchpad tm4c123g. can i program this launch pad with linux...??
If yes, can any body tel where can get supported files, documents etc..??
Hello Nick
There is a thread on the Forum for Linux and Android. Suggest you to search
http://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/t/339662.aspx
Amit
Hi Petrei
Thanks for reply. I read the post as running Linux on TM4C123
Amit
Amit Ashara said:Thanks for reply. I read the post as running Linux on TM4C123
Hi Amit, <<Hall of fame>> is driving you exhausted ;)
Developing on Linux can be done with CCS using TI compiler, GCC or Energia sketch with debug support.
Energia alone to port/use Arduino thing as they are (no debug support)
GCC and your preferred IDE, I am also using Code::Block to develop Linux code and MSP too, I see ARM support is offered but I prefer a commercial solution.
Many other you can setup as from your taste.
