Other Parts Discussed in Thread: TMP006
I have been wanting to test the Sensor Hub with my Tiva Connected Launchpad. But, upon comparing pin connections of Sensor Hub to Tiva Connected Launchpad, some seems not right. Also, I am using the sensor library "temperature_tmp006" example program as reference, and upon checking some initialization, it seems it won't work.
I don't want to power my Tiva Connected Launchpad connected with Sensor Hub Booster Pack, as I don't want to break it, with my initial findings. I want to confirm with TI, if Sensor Hub was indeed tested with Tiva Connected Launchpad. Also, which Tiva connected Launchpad boosterpack header connector should the Sensor Hub Booser Pack be connected as there is two.
Any forum member here have tried Sensor Hub Booster Pack with Tiva Connected Launchpad?
References:
Tivaware for Tiva Connected Launchpad
http://www.ti.com/lit/ug/spmu290/spmu290.pdf
http://www.ti.com/lit/ug/spmu365a/spmu365a.pdf
- kel
