Pb between Green Hills Tools and F021 library
We are using the MULTI IDE and compiler from Green Hills to build our application for an RM48xx.
But when we try to use the F021 library , the built fails (see below).
It seems there is an issue between the GHS tools and the F012 library.
What should we do ?
Archiving... Stage 2
[elxr] (warning) section .text:Fapi_issueAsyncCommandWithAddress from F021_API_C
ortexR4_LE_V3D16.lib(Async.WithAddress.obj) isn't included by the section map;
appending after last section.
add to section map or use -append to append without warning
[elxr] (error) symbol __TI_DW.debug_info.Types.h.6b0d863bb35e66291c674872428ad32
9 multiply defined in:
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(Async.WithAddress.obj)
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(FlashStateMachine.EnableMainSec
tors.obj)
[elxr] (error) symbol __TI_DW.debug_info.Read.h.228a31bd8be4049c5337fb30bb349ccd
tors.obj)
[elxr] (error) symbol __TI_DW.debug_info.Registers_FMC_LE.h.61583c6d32330081dd45
2a1f8a82c976 multiply defined in:
tors.obj)
[elxr] (error) symbol __TI_DW.debug_info.Internal_Registers_FMC_LE.h.d617fdaaa02
7215bd07ea3bfd3f29c1b multiply defined in:
tors.obj)
[elxr] (error) symbol __TI_DW.debug_info.Registers.h.4ac4d6b4935630eb633c44f964c
02e4d multiply defined in:
tors.obj)
[elxr] (error) symbol __TI_DW.debug_info.Internal_Registers.h.c7e76ae868dc355c76
ddcb3aafa094d6 multiply defined in:
tors.obj)
[elxr] (error) symbol __TI_DW.debug_info.$base_types.c8c38483d660372cd0639543647
5430b multiply defined in:
tors.obj)
[elxr] (error) symbol __TI_DW.debug_info.stdint.h.066348b889ca56249dcd34de012469
54 multiply defined in:
tors.obj)
[elxr] (error) symbol __TI_DW.debug_info.stddef.h.8673649c8983713a882827d6545ac8
ec multiply defined in:
tors.obj)
[elxr] (warning) section .text:Fapi_enableMainBankSectors from F021_API_CortexR4
_LE_V3D16.lib(FlashStateMachine.EnableMainSectors.obj) isn't included by the sec
tion map;
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(FlashStateMachine.InitializeFla
shBanks.obj)
shBanks.obj)
shBanks.obj)
shBanks.obj)
shBanks.obj)
shBanks.obj)
shBanks.obj)
shBanks.obj)
shBanks.obj)
[elxr] (warning) section .text:_Fapi_divideUnsignedLong from F021_API_CortexR4_L
E_V3D16.lib(FlashStateMachine.InitializeFlashBanks.obj) isn't included by the se
ction map;
[elxr] (warning) section .text:Fapi_initializeFlashBanks from F021_API_CortexR4_
LE_V3D16.lib(FlashStateMachine.InitializeFlashBanks.obj) isn't included by the s
ection map;
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(FlashStateMachine.IssueFsmComma
nd.obj)
nd.obj)
nd.obj)
nd.obj)
nd.obj)
nd.obj)
nd.obj)
nd.obj)
nd.obj)
[elxr] (warning) section .text:_Fapi_issueFsmCommand from F021_API_CortexR4_LE_V
3D16.lib(FlashStateMachine.IssueFsmCommand.obj) isn't included by the section ma
p;
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(FlashStateMachine.ScaleFclk.obj
[elxr] (warning) section .text:_scaleMainFclk from F021_API_CortexR4_LE_V3D16.li
b(FlashStateMachine.ScaleFclk.obj) isn't included by the section map;
[elxr] (warning) section .text:_scaleEEFclk from F021_API_CortexR4_LE_V3D16.lib(
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(FlashStateMachine.SetActiveBank
.obj)
.obj)
.obj)
.obj)
.obj)
.obj)
.obj)
.obj)
.obj)
[elxr] (warning) section .text:Fapi_setActiveFlashBank from F021_API_CortexR4_LE
_V3D16.lib(FlashStateMachine.SetActiveBank.obj) isn't included by the section ma
p;
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(Program.obj)
[elxr] (warning) section .text:Fapi_issueProgrammingCommand from F021_API_Cortex
R4_LE_V3D16.lib(Program.obj) isn't included by the section map;
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(Read.MarginByByte.obj)
[elxr] (warning) section .text:Fapi_doMarginReadByByte from F021_API_CortexR4_LE
_V3D16.lib(Read.MarginByByte.obj) isn't included by the section map;
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(Read.WdService.obj)
[elxr] (warning) section .text:_Fapi_checkWdService from F021_API_CortexR4_LE_V3
D16.lib(Read.WdService.obj) isn't included by the section map;
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(Utilities.CalculateEcc.obj)
[elxr] (warning) section .text:Fapi_calculateEcc from F021_API_CortexR4_LE_V3D16
.lib(Utilities.CalculateEcc.obj) isn't included by the section map;
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(Utilities.CalculateFletcher.obj
[elxr] (warning) section .text:Fapi_calculateFletcherChecksum from F021_API_Cort
exR4_LE_V3D16.lib(Utilities.CalculateFletcher.obj) isn't included by the section
map;
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(Read.Common.obj)
[elxr] (warning) section .text:_Fapi_readDword from F021_API_CortexR4_LE_V3D16.l
ib(Read.Common.obj) isn't included by the section map;
[elxr] (warning) section .text:_Fapi_exitMarginMode from F021_API_CortexR4_LE_V3
D16.lib(Read.Common.obj) isn't included by the section map;
[elxr] (warning) section .text:_Fapi_enterMarginMode from F021_API_CortexR4_LE_V
3D16.lib(Read.Common.obj) isn't included by the section map;
.\F021_Flash_API\F021_API_CortexR4_LE_V3D16.lib(Read.FlushPipeline.obj)
[elxr] (error) symbol __TI_DW.debug_info.Registers_FMC_LE.h.66fa4900b6d9e72f9cbf
622d2ef49901 multiply defined in:
[elxr] (error) too many errors to continue
"C:\programs\ghs\comp_201354\ccarm.exe" -language=c objs\main.o objs\sys_pmu.o .
\objs\vim_RM48x.o objs\sys_core.o objs\init_RM48x.o objs\sciFrameProt.o objs\fif
o.o objs\sci.o objs\msgFunctions.o objs\cmdResetVersion.o objs\msgValidity.o obj
s\msgProtocol.o objs\msgAddress.o objs\crypto.o objs\reset.o objs\version.o objs
\eeprom.o objs\startApp.o objs\reboot.o objs\parameters.o objs\halStdFunctions.o
objs\msgConfig.o objs\bl_flash.o objs\Fapi_UserDefinedFunctions.o tgt\standalo
ne_rm48x.ld -MD -bsp rm4xhdk,rm48 -G -align8 --ee -startfile_dir=. -L.\libstartu
p -lstartup -L.\libsys -lsys -L.\libboardinit -L.\F021_Flash_API -lboardinit -lF
021_API_CortexR4_LE_V3D16.lib -object_dir=objs -o PRIM_BOOT_RM48x.elf
BUILD FAIL
