Other Parts Discussed in Thread: HALCOGEN
I have a question about the use of code libraries from CCS and / or HALCoGen in 'certified' projects.
My interest is in the TMS570 family. As Application Report SPNA106D makes clear, the startup / init process for this device is (inevitably) complicated: in fact, there are 57 non-trivial steps identified in this document.
As I understand it, you don't release example code for this device: instead you encourage developers to use HALCoGen to create this code (using the above Application Report as a starting point).
As you will be aware, use of any third-party code in a "certified" systems can present significant challenges, and some form of Safety Manual will usually be required. I appreciate that there is a Safety Manual for the processor itself, but - unless I'm missing something - this doesn't seem to cover the library code (it appears to be "hardware only").
Can you please clarify whether there is any form of Safety Manual (or related documentation) that supports use of the HALCoGen or CCS code in IEC 61508, ISO 26262 or other "certifed" systems.
Michael.
