I've imported the usb_host_msc example int CCS Version (6.0). I'm able to build/compile a few other non-usb projects, but build keeps failing on any usb based example. I switched the arm compiler to 5.17.0 so it wouldn't throw me a warning. I've added the build/path variables and driverlib as per the instructions in the Workshop but to no avail. Any hints would be really appreciated, errors are indicated below.
Description Resource Path Location Type
unresolved symbol f_readdir, first referenced in ./usb_host_msc.obj usb_host_msc C/C++ Problem
unresolved symbol f_opendir, first referenced in ./usb_host_msc.obj usb_host_msc C/C++ Problem
unresolved symbol usnprintf, first referenced in ./usb_host_msc.obj usb_host_msc C/C++ Problem
unresolved symbol g_sCFAL96x64x16, first referenced in ./usb_host_msc.obj usb_host_msc C/C++ Problem
unresolved symbol CFAL96x64x16Init, first referenced in ./usb_host_msc.obj usb_host_msc C/C++ Problem
unresolved symbol ButtonsPoll, first referenced in ./usb_host_msc.obj usb_host_msc C/C++ Problem
unresolved symbol f_mount, first referenced in ./usb_host_msc.obj usb_host_msc C/C++ Problem
unresolved symbol SlideMenuMsgProc, first referenced in ./usb_host_msc.obj usb_host_msc C/C++ Problem
unresolved symbol ButtonsInit, first referenced in ./usb_host_msc.obj usb_host_msc C/C++ Problem
#10229-D output section ".data" refers to load symbol "g_sCFAL96x64x16" and hence cannot be compressed; compression "rle" is ignored usb_host_msc C/C++ Problem
<a href="file:/home/krithik/ti/ccsv6/tools/compiler/dmed/HTML/10234.html">#10234-D</a> unresolved symbols remain usb_host_msc C/C++ Problem
#10010 errors encountered during linking; "usb_host_msc.out" not built usb_host_msc C/C++ Problem
