Library for 128*64 GLCD based on S6B0108 chip
Dear Sir,
I was trying to write a driver for JH12864E 128*64 graphic LCD based on S6B0108 chip for the Tivaware graphic library. I am still not successful in this. Do TI or anyone else has a drive for this or close to this. This is a display with parallel GPIO interface.
With regards
Suresh
    With such exhaustive detail - so are we!  (your potential helpers)
    Myself/others may be resistant to do, "all of the work/homework" for you.  The non-detail you've provided conveys NONE of the groundwork you've (one hopes) already applied.
    Such parallel bus displays require one port for data bus - a 2nd for control & strobe signals.  And sometimes there's a requirement for a "contrast voltage" which may exceed the 3V3 found - your MCU board.  Like you - we're, "Not successful" in analyzing your condition - with the (very necessary) yet awol (nowhere to be found) detail...
    Inquiry @ Lcd vendor may prove best chance of a, "zero effort" library - although you'll still have to massage MCU into cooperation.  (and we've no clue as to your MCU - either)
