*.ccxml file
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<configurations XML_version="1.2" id="configurations_0">
<configuration XML_version="1.2" id="Spectrum Digital XDS510USB Emulator_0">
        <instance XML_version="1.2" desc="Spectrum Digital XDS510USB Emulator_0" href="connections/SD510USB_Connection.xml" id="Spectrum Digital XDS510USB Emulator_0" xml="SD510USB_Connection.xml" xmlpath="connections"/>
        <connection XML_version="1.2" id="Spectrum Digital XDS510USB Emulator_0">
            <instance XML_version="1.2" href="drivers/sdgoicepickusb_c.xml" id="drivers" xml="sdgoicepickusb_c.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/sdgocs_dapusb.xml" id="drivers" xml="sdgocs_dapusb.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/sdgocortexRusb.xml" id="drivers" xml="sdgocortexRusb.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/sdgo28xusb.xml" id="drivers" xml="sdgo28xusb.xml" xmlpath="drivers"/>
            <property Type="stringfield" Value="10" id="TCK Frequency MHz (Counter mode)"/>
            <property Type="choicelist" Value="0" id="TCK Mode"/>
            <platform XML_version="1.2" id="platform_0">
            <instance XML_version="1.2" desc="TMS570LS20216SZWT_0" href="devices/tms570ls20216szwt.xml" id="TMS570LS20216SZWT_0" xml="tms570ls20216szwt.xml" xmlpath="devices"/>
                <instance XML_version="1.2" desc="TMS320F28235_0" href="devices/f28235.xml" id="TMS320F28235_0" xml="f28235.xml" xmlpath="devices"/>
                <cpu HW_revision="1.0" XML_version="1.2" description="Bypass Cpu" deviceSim="false" id="bypass_0" isa="BYPASS08"/>
                <cpu HW_revision="1.0" XML_version="1.2" description="Bypass Cpu" deviceSim="false" id="bypass_1" isa="BYPASS08"/>
                <cpu HW_revision="1.0" XML_version="1.2" description="Bypass Cpu" deviceSim="false" id="bypass_2" isa="BYPASS08"/>
                <cpu HW_revision="1.0" XML_version="1.2" description="Bypass Cpu" deviceSim="false" id="bypass_3" isa="BYPASS08"/>
                <cpu HW_revision="1.0" XML_version="1.2" description="Bypass Cpu" deviceSim="false" id="bypass_4" isa="BYPASS08"/>
                <cpu HW_revision="1.0" XML_version="1.2" description="Bypass Cpu" deviceSim="false" id="bypass_5" isa="BYPASS08"/>
                <cpu HW_revision="1.0" XML_version="1.2" description="Bypass Cpu" deviceSim="false" id="bypass_6" isa="BYPASS08"/>
                <cpu HW_revision="1.0" XML_version="1.2" description="Bypass Cpu" deviceSim="false" id="bypass_7" isa="BYPASS08"/>
            <device HW_revision="1" XML_version="1.2" description="" id="TMS320F28235_0" partnum="TMS320F28235" simulation="no">
                    <cpu HW_revision="1.0" XML_version="1.2" description="CPU" deviceSim="false" id="C2800" isa="TMS320C28XX">
                        <property Type="choicelist" Value="1" id="bypass"/>
                    </cpu>
                </device>
            </platform>
        </connection>
    </configuration>
</configurations
Java Script to download the *.out file
function OsCodeLoad20216()
  /* Import DebugServer enving and Java packages
  importPackage(Packages.com.ti.debug.engine.scripting);
  importPackage(Packages.com.ti.ccstudio.scripting.environment);
  importPackage(Packages.java.lang);
var BASE_LOCATION="C:/MP_BUILD_081114/";
var CONFIGRATION_FILE=BASE_LOCATION+"ARM_BT/A5_XDS510.ccxml";
  var PROGRAMNAME="ARM_BT/Debug_SLAT_BUILD/ARM_BT.out";
  var BT_EXECUTABLE=BASE_LOCATION+PROGRAMNAME;
  var PROGRAMNAME="ARM_TL/Debug_SLAT_BUILD/ARM_TL.out";
  var TL_EXECUTABLE=BASE_LOCATION+PROGRAMNAME;
  var PROGRAMNAME="ARM_APP_OS/Debug_SLAT_BUILD/ARM_APP_OS.out";
  var OS_APP_EXECUTABLE=BASE_LOCATION+PROGRAMNAME;
  var PROGRAMNAME="ARM_OS/Debug_SLAT_BUILD/ARM_OS.out";
  var OS_EXECUTABLE=BASE_LOCATION+PROGRAMNAME;
  var PROGRAMNAME="ARM_SS/Debug_SLAT_BUILD/ARM_SS.out";
  var SS_EXECUTABLE=BASE_LOCATION+PROGRAMNAME;
  var PROGRAMNAME="ARM_DSR/Debug_SLAT_BUILD/ARM_DSR.out";
  var DSR_EXECUTABLE=BASE_LOCATION+PROGRAMNAME;
/* Global handles to the debugger */
var env = ScriptingEnvironment.instance();
var server = env.getServer("DebugServer.1");
// Create a log file in the current directory to log script execution
  env.traceBegin( BASE_LOCATION+"Arm20216CodeLoadLog.xml", "DefaultStylesheet.xsl");
  env.traceSetFileLevel(TraceLevel.ALL);
  /* Setting configuration */
  env.traceWrite("Setting configuration: "+CONFIGRATION_FILE);
  print("Setting configuration: "+CONFIGRATION_FILE);
  server.setConfig( CONFIGRATION_FILE );
var session = server.openSession("*","*");
  /* Connect to target */
  env.traceWrite("Connecting to device...");
  print("Connecting to device...");
session.target.connect();
  env.traceWrite("Connected.");
  print("Connected.");
  /* Set flash properties  */
   env.traceWrite("Setting flash options...");
   print("Setting flash options...");
  /* Clock settings */
  session.flash.options.setString("FlashCrystalFreq","16.0");
  session.flash.options.setString("FlashVerifySetting","Verify");
   /* sectors to erase */
   session.flash.options.setString("FlashEraseSelection", "Entire Flash");
   /* flash operations */
   env.traceWrite("Erase flash...");
   print("Erase flash...\n");
   session.flash.erase();
   session.flash.options.setString("FlashEraseSelection", "Selected Sectors Only");
   env.traceWrite("Setting flash sectors...");
   print("Setting flash options sectors...");
   session.flash.options.setBoolean("FlashBank0Sector0",false);
   session.flash.options.setBoolean("FlashBank0Sector1",false);
   session.flash.options.setBoolean("FlashBank0Sector2",false);
   session.flash.options.setBoolean("FlashBank0Sector3",false);
   session.flash.options.setBoolean("FlashBank0Sector4",false);
   session.flash.options.setBoolean("FlashBank0Sector5",false);
   session.flash.options.setBoolean("FlashBank0Sector6",false);
   session.flash.options.setBoolean("FlashBank0Sector7",false);
   session.flash.options.setBoolean("FlashBank0Sector8",false);
   session.flash.options.setBoolean("FlashBank0Sector9",false);
   session.flash.options.setBoolean("FlashBank1Sector0",false);
   session.flash.options.setBoolean("FlashBank1Sector1",false);
   session.flash.options.setBoolean("FlashBank1Sector2",false);
   session.flash.options.setBoolean("FlashBank1Sector3",false);
   session.flash.options.setBoolean("FlashBank2Sector0",false);
   session.flash.options.setBoolean("FlashBank2Sector1",false);
   session.flash.options.setBoolean("FlashBank2Sector2",false);
   session.flash.options.setBoolean("FlashBank2Sector3",false);
   session.flash.options.setBoolean("FlashBank3Sector0",false);
   session.flash.options.setBoolean("FlashBank3Sector1",false);
   session.flash.options.setBoolean("FlashBank3Sector2",false);
   session.flash.options.setBoolean("FlashBank3Sector3",false);
   env.traceWrite("Setting auto run options...");
   print("Setting auto run options...");
   session.options.setBoolean("AutoRunToLabelOnRestart",false)
   session.options.setBoolean("AutoRunToLabelOnReset",false)
  try{
    /* Load the Program */
    print("");
    env.traceWrite("Load Programs...");
    print("Loading.Programs...");
    env.traceWrite("Load Program: "+BT_EXECUTABLE);
    print("Load Program: "+BT_EXECUTABLE);
    env.traceWrite("Loading...");
    print("Loading...");
    session.memory.loadProgram(BT_EXECUTABLE);
    env.traceWrite("Load Program: "+TL_EXECUTABLE);
    print("Load Program: "+TL_EXECUTABLE);
    session.memory.loadProgram(TL_EXECUTABLE);
    env.traceWrite("Load Program: "+SS_EXECUTABLE);
    print("Load Program: "+SS_EXECUTABLE);
    session.memory.loadProgram(SS_EXECUTABLE);
    env.traceWrite("Load Program: "+DSR_EXECUTABLE);
    print("Load Program: "+DSR_EXECUTABLE);
    session.memory.loadProgram(DSR_EXECUTABLE);
    env.traceWrite("Load Program: "+OS_EXECUTABLE);
    print("Load Program: "+OS_EXECUTABLE);
    session.memory.loadProgram(OS_EXECUTABLE);
    env.traceWrite("Load Program: "+OS_APP_EXECUTABLE);
    print("Load Program: "+OS_APP_EXECUTABLE);
    session.memory.loadProgram(OS_APP_EXECUTABLE);
    print("");
    env.traceWrite("Load Symbols...");
    print("Loading.Symbols...");
    env.traceWrite("Load Symbols: "+OS_APP_EXECUTABLE);
    print("Load Symbols: "+OS_APP_EXECUTABLE);
    session.symbol.add(OS_APP_EXECUTABLE);
    env.traceWrite("Load Symbols: "+OS_EXECUTABLE);
    print("Load Symbols: "+OS_EXECUTABLE);
    session.symbol.add(OS_EXECUTABLE);
    env.traceWrite("Load Symbols: "+DSR_EXECUTABLE);
    print("Load Symbols: "+DSR_EXECUTABLE);
    session.symbol.add(DSR_EXECUTABLE);
    env.traceWrite("Load Symbols: "+SS_EXECUTABLE);
    print("Load Symbols: "+SS_EXECUTABLE);
    session.symbol.add(SS_EXECUTABLE);
    env.traceWrite("Load Symbols: "+TL_EXECUTABLE);
    print("Load Symbols: "+TL_EXECUTABLE);
    session.symbol.add(TL_EXECUTABLE);
    env.traceWrite("Load Symbols: "+BT_EXECUTABLE);
    print("Load Symbols: "+BT_EXECUTABLE);
    session.symbol.add(BT_EXECUTABLE);
    env.traceWrite("Program & Symbols Loaded.");
    print("Program & Symbols Loaded.");
    /* Get Flash Checksum */
    //session.flash.calculateChecksum();
  catch(err)
    env.traceWrite("Error in 20216 Load / Flash Programming.");
hotmenu.addJSFunction("OsCodeLoad20216","OsCodeLoad20216()");
/* End session, since the tests are done */
//server.stop();
//session.terminate();
Emulator: XDS510 PLUS
Code Composer Studio: Ver 5.4.0
Target Processor: TMS570LS20216SZWT
Attached the error snap shot, target configuration and Java script file for the reference.2744.Error.zip
Getting the below error message when I am trying to download the software into the customized target board, can some one please let me know the error cause.
IcePick: Power Failure on Target CPU
IcePick: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
CortexR4: Power Failure on Target CPU
CortexR4: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging.
