TM4C1294 Generate an interrupt every 100ms
I am trying to generate an interrupt every 100ms and it does not seem to be working. I have attached me code below. What am I doing wrong?1854.TM4C1294_Timer.zip
  • Hi Andrew,
    You don't configure the Timer to any mode. For what you need you want it in TIMER_CFG_PERIODIC
    Also since the TimerIntClear takes a few cycles to happen, it's advised to be called at the begining of the interrupt handler.
  • Hello Luis,
    Thank you for your help. I applied your suggestion but I am still not getting the interrupt to trigger. I have attached my updated code below. Did I implement your suggestion correctly?
    1212.TM4C1294_Timer.zip
  • Hi Andrew,
    I only noticed now, you forgot  SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);
  • Most always - failing to first, "SysCtlPeripheralEnable()" - and then placing a call to that peripheral - causes a hard fault.
    Poster reported only, " does not seem to be working."   While that's surely true - description that empty/vague is essentially meaningless.  Of course poster's are frustrated - yet imprecise communication does not best serve their interest...
    Report of entry into Fault ISR - immediately upon execution of that Timer call - would have eased/speeded Luis's diagnosis.
