Other Parts Discussed in Thread: TM4C123GH6PM
Hi
everyone,
I have given a proper sine signal with 100 mv amp,25hz freq+200mv offset to 4 channels of tm4c123gh6pm adc.i am using the same input for 4 channels for experimental purpose..The samples are not coming in a particular order,here i have uploaded my code and the graph of the data i am getting from one channel.Please have a look.
// single_ended.c - Example demonstrating how to configure the ADC for
// single ended operation.
// Copyright (c) 2010-2013 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// This is part of revision 2.0.1.11577 of the Tiva Firmware Development Package.
#include <stdbool.h>
#include <stdint.h>
#include "hw_memmap.h"
#include "adc.h"
#include "gpio.h"
#include "pin_map.h"
#include "sysctl.h"
#include "uart.h"
#include "uartstdio.h"
#include "timer.h"
//! \addtogroup adc_examples_list
//! <h1>Single Ended ADC (single_ended)</h1>
//! This example shows how to setup ADC0 as a single ended input and take a
//! single sample on AIN0/PE7.
//! This example uses the following peripherals and I/O signals. You must
//! review these and change as needed for your own board:
//! - ADC0 peripheral
//! - GPIO Port E peripheral (for AIN0 pin)
//! - AIN0 - PE7
//! The following UART signals are configured only for displaying console
//! messages for this example. These are not required for operation of the
//! ADC.
//! - UART0 peripheral
//! - GPIO Port A peripheral (for UART0 pins)
//! - UART0RX - PA0
//! - UART0TX - PA1
//! This example uses the following interrupt handlers. To use this example
//! in your own application you must add these interrupt handlers to your
//! vector table.
//! - None.
// This function sets up UART0 to be used for a console to display information
// as the example is running.
/*void
InitConsole(void)
// Enable GPIO port A which is used for UART0 pins.
// TODO: change this to whichever GPIO port you are using.
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
// Configure the pin muxing for UART0 functions on port A0 and A1.
// This step is not necessary if your part does not support pin muxing.
// TODO: change this to select the port/pin you are using.
GPIOPinConfigure(GPIO_PA0_U0RX);
GPIOPinConfigure(GPIO_PA1_U0TX);
// Enable UART0 so that we can configure the clock.
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
// Use the internal 16MHz oscillator as the UART clock source.
UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC);
// Select the alternate (UART) function for these pins.
GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
// Initialize the UART for console I/O.
UARTStdioConfig(0, 115200, 16000000);
// Configure ADC0 for a single-ended input and a single sample. Once the
// sample is ready, an interrupt flag will be set. Using a polling method,
// the data will be read then displayed on the console via UART0.
int
main(void)
// This array is used for storing the data read from the ADC FIFO. It
// must be as large as the FIFO for the sequencer in use. This example
// uses sequence 3 which has a FIFO depth of 1. If another sequence
// was used with a deeper FIFO, then the array size must be changed.
uint32_t pui32ADC0Value1[1],pui32ADC0Value2[1],pui32ADC0Value3[1],pui32ADC0Value4[1];
uint32_t data1[100],data2[100],data3[100],data4[100];
int i=100;
// Set the clocking to run at 20 MHz (200 MHz / 10) using the PLL. When
// using the ADC, you must either use the PLL or supply a 16 MHz clock
// source.
// TODO: The SYSCTL_XTAL_ value must be changed to match the value of the
// crystal on your board.
SysCtlClockSet(SYSCTL_SYSDIV_10 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |
SYSCTL_XTAL_16MHZ);
// Set up the serial console to use for displaying messages. This is
// just for this example program and is not needed for ADC operation.
//InitConsole();
// Display the setup on the console.
// UARTprintf("ADC ->\n");
// UARTprintf(" Type: Single Ended\n");
//UARTprintf(" Samples: One\n");
//UARTprintf(" Update Rate: 250ms\n");
//UARTprintf(" Input Pin: AIN0/PE7\n\n");
// The ADC0 peripheral must be enabled for use.
SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
// For this example ADC0 is used with AIN0 on port E7.
// The actual port and pins used may be different on your part, consult
// the data sheet for more information. GPIO port E needs to be enabled
// so these pins can be used.
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
// Select the analog ADC function for these pins.
// Consult the data sheet to see which functions are allocated per pin.
/*timer***********************************/
SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);
TimerConfigure(TIMER0_BASE,TIMER_CFG_PERIODIC);
TimerLoadSet(TIMER0_BASE, TIMER_A,20000); /*set the timer to fs=2 ksps load value */
/*if timer loading value=5000; fs=1 ksps
* sysclock=20mhz so tsys=1/2000000sec;to get 1ms delay
*we need to load timer with 1ms/0.5us***/
TimerEnable(TIMER0_BASE, TIMER_A);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_2);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_1);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_4);
// Enable sample sequence 3 with a processor signal trigger. Sequence 3
// will do a single sample when the processor sends a signal to start the
// conversion. Each ADC module has 4 programmable sequences, sequence 0
// to sequence 3. This example is arbitrarily using sequence 3.
// ADCSequenceConfigure(ADC0_BASE, 3, ADC_TRIGGER_PROCESSOR, 0);
// ADCSequenceConfigure(ADC0_BASE, 3, ADC_TRIGGER_TIMER, 0);
// Configure step 0 on sequence 3. Sample channel 0 (ADC_CTL_CH0) in
// single-ended mode (default) and configure the interrupt flag
// (ADC_CTL_IE) to be set when the sample is done. Tell the ADC logic
// that this is the last conversion on sequence 3 (ADC_CTL_END). Sequence
// 3 has only one programmable step. Sequence 1 and 2 have 4 steps, and
// sequence 0 has 8 programmable steps. Since we are only doing a single
// conversion using sequence 3 we will only configure step 0. For more
// information on the ADC sequences and steps, reference the datasheet.
TimerControlTrigger(TIMER0_BASE, TIMER_A, true);
for(i=0;i<100;i++)
ADCSequenceStepConfigure(ADC0_BASE, 3, 0, ADC_CTL_CH0 | ADC_CTL_IE |
ADC_CTL_END);
// Since sample sequence 3 is now configured, it must be enabled.
ADCSequenceEnable(ADC0_BASE, 3);
// Clear the interrupt status flag. This is done to make sure the
// interrupt flag is cleared before we sample.
ADCIntClear(ADC0_BASE, 3);
// Sample AIN0 forever. Display the value on the console.
// while(1)
//for(i=0;i<100;i++)
// Trigger the ADC conversion.
// ADCProcessorTrigger(ADC0_BASE, 3);
//TimerControlTrigger(TIMER0_BASE, TIMER_A, true);
// Wait for conversion to be completed.
while(!ADCIntStatus(ADC0_BASE, 3, false))
// Clear the ADC interrupt flag.
// Read ADC Value.
ADCSequenceDataGet(ADC0_BASE, 3, pui32ADC0Value1);
//i= pui32ADC0Value;
// Display the AIN0 (PE7) digital value on the console.
// UARTprintf("AIN0 = %4d\r", pui32ADC0Value[0]);
data1[i]=pui32ADC0Value1[0];
//SysCtlDelay(2000);
ADCSequenceDisable(ADC0_BASE, 3);
// pui32ADC0Value[0]=0;
// This function provides a means of generating a constant length
// delay. The function delay (in cycles) = 3 * parameter. Delay
// 250ms arbitrarily.
// SysCtlDelay(SysCtlClockGet() / 12);
//SysCtlDelay(250);
ADCSequenceStepConfigure(ADC0_BASE, 3, 0, ADC_CTL_CH1 | ADC_CTL_IE |
ADC_CTL_END);
ADCSequenceDataGet(ADC0_BASE, 3, pui32ADC0Value2);
data2[i]=pui32ADC0Value2[0];
//SysCtlDelay(250);
ADCSequenceStepConfigure(ADC0_BASE, 3, 0, ADC_CTL_CH2 | ADC_CTL_IE |
ADC_CTL_END);
ADCSequenceDataGet(ADC0_BASE, 3, pui32ADC0Value3);
data3[i]=pui32ADC0Value3[0];
//SysCtlDelay(250);
ADCSequenceStepConfigure(ADC0_BASE, 3, 0, ADC_CTL_CH9 | ADC_CTL_IE |
ADC_CTL_END);
ADCSequenceDataGet(ADC0_BASE, 3, pui32ADC0Value4);
data4[i]=pui32ADC0Value4[0];
// SysCtlDelay(250);
while(1);
This no way looks like a sine what i am giving as input.I dnt understand where i am doing wrong.As per my calculation my adc is working with 500sps for each channel as after 1 ms i am switching the channel and there are 4 channels in total i am using.Why i am not getting a proper data.please help me with this.
Arun
