fuzzy logic
 i want to implement a fuzzy logic based mppt controller using tm4c123g.is it posible to implemet it?
can anybody share the idea to implement this?
  • Recall past presidential comment, "Depends upon what "is" is!"  (still delightful)
    Most anything is "possible" -  you may better move to, "Is it efficient, does it make (proper) use of MCU's in-built resources, and what alternatives are available?"
    I know MPPT primarily as employed w/solar panels/controllers.  Your usage is unstated.
    Has your investigation revealed MPPT forums - or in-depth usage groups?  Suspect that would be more productive - others have implemented.   Response here will (likely) try to, "fit the horse (MCU) to the cart (MPPT) App."  Would not a superior tack be to investigate & find those MCU features most required/beneficial to MPPT - and then choose the best matched MCU?
