Other Parts Discussed in Thread: LAUNCHXL-TMS57004, LAUNCHXL2-TMS57012
Unfortunately I see no screw holes in the Hercules that could be used to mount the Hercules in an enclosure box. Does anybody have any good ideas for do the mounting?
Maybe consider...
http://www.mouser.com/ProductDetail/TE-Connectivity-AMP/4TK2-48/?qs=sGAEpiMZZMsOthVV91%2fyqMtDZFQnUZBU
You will have to cut the SnapTrak because your board is only 2 inches wide. But at least you'll avoid modifying the board.
Those holes are test points connected to ground. I wouldn't rely on then. But I guess you can try nylon screws (do not use metal!). It really depends how much mechanical vibration your application will see.
You can get layout/Gerber files here...
http://processors.wiki.ti.com/images/b/b0/Hercules_LaunchPad_SchLayout.zip
