Other Parts Discussed in Thread: TM4C129DNCPDT
I am using CCS 6.0.1.40 with compiler TIv5.1.6.
I am configuring USB in serial configuration to use as virtual serial port in TM4C129DNCPDT.
my code runs successfully and the COM port detect by the PC and i can successfully communicate with device with teraterm and with my labview and matlab software.
But some times if i modify or add some code in any random file which haven't any relation with USB in those cases the COM port is detected by PC and also i get USB connect and disconnect even in ControlHandler of USB. But Labview and Matlab unable to open that port but teraterm can open port and successfully able to communicate.
But if i add some more lines or just copy some instructions and paste below or delete some lines then Labview and Matlab can successfully communicate with my device.
I have noticed that by adding or removing some instructions the Memory assignment of functions modified in map file so i think that in problem conditions the USB related functions address might get overlapped or changed.
I have also compare CCS project properties with example code.
