Stellaris Launchpad (EX-LM4F120XL) Multi-Threading? Example code?
I have an application to work on that I feel might be best implemented using multiple threads.
I have a Stellaris Launchpad (EX-LM4F120XL) and I'm wondering if this device can be made to run multiple threads.
If so, can I do this using the free IAR Kickstart IDE?
Does anyone know of a multi-threaded example to work from?
Thanks!
  • Hello David,
    Please have a look at the following threads that have been raised for multi-threaded examples and implementations
    http://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/p/293282/1024469#1024469
    http://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/p/364829/1282483#1282483
    http://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/t/376100
    Amit
  • Thanks, Amit. I did a quick scan of those threads and I think I found a preliminary answer:
    The Stellaris WON'T do true multi-threading, but an RTOS will do some fancy task switching that could be a proxy for true multi-threading. Is that a reasonable synopsis?
    Just as an aside, does TI make a microprocessor that DOES true multi-threading and is there an eval board I can play with?
    Thank you!
  • Hello David
    There are other processors in the Sitara family of device which support multi threaded applications
    Amit
