I am having issues interfacing sd card with LM4f232h5qd. Are there any pre defined header files or example codes available which I could use? I tried searching the ti website but couldn't find any solutions.
You may also (better) match your Stellaris MCU via: StellarisWare9453\boards\ek-lm4f232\sd_card.
Your report (having issues) is too vague to enable any meaningful comment.
Have you loaded that file - complied w/readme guides - and noted specific issues?
In addition - we note this is your first post - have you prior experience w/MCUs in general - and w/this "ARM" class in specific?
Unwise to "start" with an advanced peripheral - have you experimented w/GPIO, Timers, and spent time reviewing the SPI chapter w/in MCU manual?
There is a rather detailed example w/in past StellarisWare - exactly matching your (now) indicated desire.
Suggest that you read/review - then compile, download & explore.
Amit's point re: "compatibility w/PC for data read/write" of course has value - but does (possibly) add complication & effort. (it's been years since we've used our EK232 boards (we were "gifted" 3 by vendor) and I don't recall if PC support was included w/in that sd_card code example...
My 1st post listed (and directed you to) an sd card code example - basic responsibility to judge it's value falls more upon you than others...
