Other Parts Discussed in Thread: HALCOGEN
I am driving a step by step motor from two N2HET signals in RM48 microcontroller.
I want to up/down count the pulses sent to the step by step motor.
I tried to use the ECNT instruction of N2HET on the output signal but this does not work.
I see it’s not possible to share an output signal with the input on the associated pin.
Do you know a simple solution to count the emitted pulses on output N2HET signal ?
Thank a lot for your help
