TM4C129 Web Server and DynDNS.
Is there a example project "for example enet_io" to access our EK-TM4C129 interface for an external network by setting up a DynDns address?
The idea is to be possible to access the interface of an outside network by setting up a DynDNS address in the interface.
Aquino
  • Hello Aquino,
    Do you mean TM4C129 Hosting a web page and outside the LAN for eg. a PC to access it?
    Amit
  • Hi Amit,
    That's what I mean.
    Be possible to set up a DynDNS address in our interface, to be able to access outside the network.
    Aquino
  • Amit, I am sorry but I have to say you I leave this forum at your hand, I learn all came here asking have solution ready and again instead of figuring how to recompile DynDNS examples just ask to have someone do for him and when someone give hint forever attack arrogantly as usual habit.
    Amit, I think about another solution, I read seldom real issue with processor and now all forum is poisoned by, original split was an idea to filter all on a first come first moved, now noise is too loud and information has to digged by wavelet or fine filter. Try ask developer if instead of "Like" a "Filter out", "block poster" can be added as a feature we need to avoid waste our precious time.
     Edit...
     P.S: some year ago I recompiled and customized client to run as deamon on BSD host, this required no more than 20 minutes to test and run than askinfg to have what I need form provider.
  • ehehehe
    Roberto thank you for your response. But forgot to send the book link...
    Best Regards
    Aquino
