Hey guys, I am trying to display a voltage on my LCD touch screen
I'm working with the TM4C123GH6PM.
The problem is that i can't seem to update the value of ADC.
Does anyone have an idea of how to do this? (see last function p
// scribble.c - A simple scribble pad to demonstrate the touch screen driver.
#include <stdint.h>
#include <stdbool.h>
#include "inc/hw_memmap.h"
#include "inc/hw_nvic.h"
#include "inc/hw_sysctl.h"
#include "inc/hw_types.h"
#include "driverlib/fpu.h"
#include "driverlib/gpio.h"
#include "driverlib/flash.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "driverlib/uart.h"
#include "driverlib/udma.h"
#include "driverlib/rom.h"
#include "grlib/grlib.h"
#include "grlib/widget.h"
#include "grlib/canvas.h"
#include "grlib/checkbox.h"
#include "grlib/container.h"
#include "grlib/pushbutton.h"
#include "grlib/radiobutton.h"
#include "grlib/slider.h"
#include "utils/ustdlib.h"
#include "drivers/Kentec320x240x16_ssd2119_8bit.h"
//#include "drivers/sound.h"
#include "drivers/touch.h"
//#include "drivers/set_pinout.h"
#include "images.h"
#define ADC1_ISC_R (*((volatile unsigned long *)0x4003900C))
#define GPIO_PORTF_DATA_R (*((volatile unsigned long *)0x400253FC))
#define ADC0_SSFIFO3_R (*((volatile unsigned long *)0x400380A8))
#define ADC_SSFIFO3_DATA_M 0x00000FFF // Conversion Result Data
void Init_ADC (void);
//! \addtogroup example_list
//! <h1>Scribble Pad (scribble)</h1>
//! The scribble pad provides a drawing area on the screen. Touching the
//! screen will draw onto the drawing area using a selection of fundamental
//! colors (in other words, the seven colors produced by the three color
//! channels being either fully on or fully off). Each time the screen is
//! touched to start a new drawing, the drawing area is erased and the next
//! color is selected.
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, unsigned long ulLine)
#endif
#define __FPU_PRESENT 1
#define ARM_MATH_CM4
#include "arm_math.h"
#include "arm_const_structs.h"
volatile float32_t ADCvalue;
volatile float32_t Voltage;
volatile float32_t Pressure;
// The DMA control structure table.
#ifdef ewarm
#pragma data_alignment=1024
tDMAControlTable sDMAControlTable[64];
#elif defined(ccs)
#pragma DATA_ALIGN(sDMAControlTable, 1024)
#else
tDMAControlTable sDMAControlTable[64] __attribute__ ((aligned(1024)));
#endif
// Forward declarations for the globals required to define the widgets at
// compile-time.
void OnPrevious(tWidget *pWidget);
void OnNext(tWidget *pWidget);
void OnIntroPaint(tWidget *pWidget, tContext *pContext);
void OnPrimitivePaint(tWidget *pWidget, tContext *pContext);
void OnCanvasPaint(tWidget *pWidget, tContext *pContext);
void OnCheckChange(tWidget *pWidget, uint32_t bSelected);
void OnButtonPress(tWidget *pWidget);
void OnRadioChange(tWidget *pWidget, uint32_t bSelected);
void OnSliderChange(tWidget *pWidget, int32_t lValue);
extern tCanvasWidget g_psPanels[];
volatile int z=0;
// The first panel, which contains introductory text explaining the
// application.
Canvas(g_sIntroduction, g_psPanels, 0, 0, &g_sKentec320x240x16_SSD2119, 0, 24,
320, 166, CANVAS_STYLE_APP_DRAWN, 0, 0, 0, 0, 0, 0, OnIntroPaint);
// The second panel, which demonstrates the graphics primitives.
tContainerWidget g_psRadioContainers[];
tCanvasWidget g_psRadioButtonIndicators[] =
CanvasStruct(g_psRadioContainers, g_psRadioButtonIndicators + 1, 0,
&g_sKentec320x240x16_SSD2119, 120, 62, 20, 20,
CANVAS_STYLE_IMG, 0, 0, 0, 0, 0, g_pucLightOff, 0),
CanvasStruct(g_psRadioContainers, g_psRadioButtonIndicators + 2, 0,
&g_sKentec320x240x16_SSD2119, 120, 107, 20, 20,
CanvasStruct(g_psRadioContainers, 0, 0,
&g_sKentec320x240x16_SSD2119, 120, 152, 20, 20,
tCanvasWidget g_psPushButtonIndicators[] =
CanvasStruct(g_psRadioContainers + 1, 0, 0,
&g_sKentec320x240x16_SSD2119, 190, 115, 20, 20,
tCanvasWidget g_psText[] =
CanvasStruct(g_psRadioContainers + 2, 0, 0,
&g_sKentec320x240x16_SSD2119, 120, 35, 195, 76,
CANVAS_STYLE_TEXT,ClrMidnightBlue, ClrWhite, ClrWhite, &g_sFontCm22, "NASER", 0, 0),
tRadioButtonWidget g_psRadioButtons1[] =
RadioButtonStruct(g_psRadioContainers, g_psRadioButtons1 + 1, 0,
&g_sKentec320x240x16_SSD2119, 10, 50, 100, 45,
RB_STYLE_TEXT, 16, 0, ClrLightGreen, ClrWhite, &g_sFontCm20,
" mL H20", 0, OnRadioChange),
RadioButtonStruct(g_psRadioContainers, g_psRadioButtons1 + 2, 0,
&g_sKentec320x240x16_SSD2119, 10, 95, 100, 45,
" milliBar", 0, OnRadioChange),
RadioButtonStruct(g_psRadioContainers, g_psRadioButtonIndicators, 0,
&g_sKentec320x240x16_SSD2119, 10, 140, 100, 45,
" Pascal", 0, OnRadioChange),
#define NUM_RADIO1_BUTTONS (sizeof(g_psRadioButtons1) / \
sizeof(g_psRadioButtons1[0]))
tPushButtonWidget g_psPushButtons[] =
RectangularButtonStruct(g_psRadioContainers + 1, g_psPushButtons + 1, 0,
&g_sKentec320x240x16_SSD2119, 170, 140, 70, 40,
PB_STYLE_FILL | PB_STYLE_OUTLINE | PB_STYLE_TEXT,
ClrRed, ClrBlack, ClrWhite, ClrWhite,
&g_sFontCm22, "Hold", 0, 0, 0, 0, OnButtonPress),
RectangularButtonStruct(g_psRadioContainers + 1, g_psRadioButtonIndicators + 3, 0,
&g_sKentec320x240x16_SSD2119, 243, 140, 70, 40,
ClrLightGreen, ClrBlack, ClrWhite, ClrWhite,
&g_sFontCm22, "Save", 0, 0, 0, 0, OnButtonPress),
#define NUM_PUSH_BUTTONS (sizeof(g_psPushButtons) / \
sizeof(g_psPushButtons[0]))
unsigned long g_ulButtonState;
tContainerWidget g_psRadioContainers[] =
ContainerStruct(g_psPanels + 1, g_psRadioContainers + 1 , g_psRadioButtons1,
&g_sKentec320x240x16_SSD2119, 5, 27, 148, 160,
CTR_STYLE_OUTLINE | CTR_STYLE_TEXT, 0, ClrWhite, ClrWhite,
&g_sFontCm20, "Unit"),
ContainerStruct(g_psPanels + 1, g_psRadioContainers + 2, g_psPushButtons,
&g_sKentec320x240x16_SSD2119, 167, 110, 148, 50,
CTR_STYLE_OUTLINE | CTR_STYLE_TEXT, 0, 0, 0,
&g_sFontCm20, "Fonctions"),
ContainerStruct(g_psPanels + 1, 0, g_psText,
&g_sKentec320x240x16_SSD2119, 167, 27, 148, 75,
&g_sFontCm20, "Pression"),
// An array of canvas widgets, one per panel. Each canvas is filled with
// black, overwriting the contents of the previous panel.
tCanvasWidget g_psPanels[] =
CanvasStruct(0, 0, &g_sIntroduction, &g_sKentec320x240x16_SSD2119, 0, 24,
320, 166, CANVAS_STYLE_FILL, ClrBlack, 0, 0, 0, 0, 0, 0),
CanvasStruct(0, 0, g_psRadioContainers, &g_sKentec320x240x16_SSD2119, 0,
24, 320, 166, CANVAS_STYLE_FILL, ClrBlack, 0, 0, 0, 0, 0, 0),
// The number of panels.
#define NUM_PANELS (sizeof(g_psPanels) / sizeof(g_psPanels[0]))
// The names for each of the panels, which is displayed at the bottom of the
// screen.
char *g_pcPanelNames[] =
" Overview ",
" Mesurements "
// The buttons and text across the bottom of the screen.
RectangularButton(g_sPrevious, 0, 0, 0, &g_sKentec320x240x16_SSD2119, 0, 190,
80, 50, PB_STYLE_FILL, ClrBlack, ClrBlack, 0, ClrWhite,
&g_sFontCm20, "-", g_pucBlue50x50, g_pucBlue50x50Press, 0, 0,
OnPrevious);
Canvas(g_sTitle, 0, 0, 0, &g_sKentec320x240x16_SSD2119, 50, 190, 220, 50,
CANVAS_STYLE_TEXT | CANVAS_STYLE_TEXT_OPAQUE, 0, 0, ClrGold,
&g_sFontCm20, 0, 0, 0);
RectangularButton(g_sNext, 0, 0, 0, &g_sKentec320x240x16_SSD2119, 250, 190,
80, 50, PB_STYLE_IMG | PB_STYLE_TEXT, ClrBlack, ClrBlack, 0,
ClrWhite, &g_sFontCm20, "+", g_pucBlue50x50,
g_pucBlue50x50Press, 0, 0, OnNext);
// The panel that is currently being displayed.
unsigned long g_ulPanel;
// Handles presses of the previous panel button.
void
// There is nothing to be done if the first panel is already being
// displayed.
if(g_ulPanel == 0)
return;
// Remove the current panel.
WidgetRemove((tWidget *)(g_psPanels + g_ulPanel));
// Decrement the panel index.
g_ulPanel--;
// Add and draw the new panel.
WidgetAdd(WIDGET_ROOT, (tWidget *)(g_psPanels + g_ulPanel));
WidgetPaint((tWidget *)(g_psPanels + g_ulPanel));
// Set the title of this panel.
CanvasTextSet(&g_sTitle, g_pcPanelNames[g_ulPanel]);
WidgetPaint((tWidget *)&g_sTitle);
// See if this is the first panel.
if(g_ulPanel == 0)
// Clear the previous button from the display since the first panel is
// being displayed.
PushButtonImageOff(&g_sPrevious);
PushButtonTextOff(&g_sPrevious);
PushButtonFillOn(&g_sPrevious);
WidgetPaint((tWidget *)&g_sPrevious);
// See if the previous panel was the last panel.
if(g_ulPanel == (NUM_PANELS - 2))
// Display the next button.
PushButtonImageOn(&g_sNext);
PushButtonTextOn(&g_sNext);
PushButtonFillOff(&g_sNext);
WidgetPaint((tWidget *)&g_sNext);
// Play the key click sound.
// SoundPlay(g_pusKeyClick, sizeof(g_pusKeyClick) / 2);
// Handles presses of the next panel button.
void
// There is nothing to be done if the last panel is already being
// displayed.
if(g_ulPanel == (NUM_PANELS - 1))
return;
// Increment the panel index.
g_ulPanel++;
// See if the previous panel was the first panel.
if(g_ulPanel == 1)
// Display the previous button.
PushButtonImageOn(&g_sPrevious);
PushButtonTextOn(&g_sPrevious);
PushButtonFillOff(&g_sPrevious);
// See if this is the last panel.
// Clear the next button from the display since the last panel is being
// displayed.
PushButtonImageOff(&g_sNext);
PushButtonTextOff(&g_sNext);
PushButtonFillOn(&g_sNext);
// Handles paint requests for the introduction canvas widget.
void
// Display the Overview of the application.
GrContextFontSet(pContext, &g_sFontCm18);
GrContextForegroundSet(pContext, ClrWhite);
GrStringDraw(pContext, "This instrument measures the pressure with accuracy", -1,
0, 32, 0);
GrStringDraw(pContext, "accuracy.", -1, 0, 50, 0);
GrStringDraw(pContext, "Many features are available in this ", -1, 0,
74, 0);
GrStringDraw(pContext, "application.", -1, 0,
92, 0);
GrStringDraw(pContext, "You can easily change the Unit of the", -1, 0,
110, 0);
GrStringDraw(pContext, "pressure and store up to 15 mesures", -1, 0,
128, 0);
GrStringDraw(pContext, "Navigate using + and - ", -1, 0,
146, 0);
// Handles press notifications for the push button widgets.
void
unsigned long ulIdx;
// Find the index of this push button.
for(ulIdx = 0; ulIdx < NUM_PUSH_BUTTONS; ulIdx++)
if(pWidget == (tWidget *)(g_psPushButtons + ulIdx))
break;
// Return if the push button could not be found.
if(ulIdx == NUM_PUSH_BUTTONS)
return;
// Toggle the state of this push button indicator.
g_ulButtonState ^= 1 << ulIdx;
// Set the matching indicator based on the selected state of the check box.
CanvasImageSet(g_psPushButtonIndicators + ulIdx,
(g_ulButtonState & (1 << ulIdx)) ? g_pucLightOn :
g_pucLightOff);
WidgetPaint((tWidget *)(g_psPushButtonIndicators + ulIdx));
// Handles change notifications for the radio button widgets.
void
// Find the index of this radio button in the first group.
for(ulIdx = 0; ulIdx < NUM_RADIO1_BUTTONS; ulIdx++)
if(pWidget == (tWidget *)(g_psRadioButtons1 + ulIdx))
break;
// See if the radio button was found.
if(ulIdx == NUM_RADIO1_BUTTONS)
return;
// Set the matching indicator based on the selected state of the radio
// button.
CanvasImageSet(g_psRadioButtonIndicators + ulIdx,
bSelected ? g_pucLightOn : g_pucLightOff);
WidgetPaint((tWidget *)(g_psRadioButtonIndicators + ulIdx));
// A simple demonstration of the features of the Stellaris Graphics Library.
int
main(void)
tContext sContext;
tRectangle sRect;
FPUEnable();
FPULazyStackingEnable();
// Set the clocking to run directly from the crystal.
SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_XTAL_16MHZ |
SYSCTL_OSC_MAIN);
Init_ADC ();
// Initialize the display driver.
Kentec320x240x16_SSD2119Init();
// Initialize the graphics context.
GrContextInit(&sContext, &g_sKentec320x240x16_SSD2119);
// Fill the top 24 rows of the screen with blue to create the banner.
sRect.i16XMin = 0;
sRect.i16YMin = 0;
sRect.i16XMax = GrContextDpyWidthGet(&sContext) - 1;
sRect.i16YMax = 23;
GrContextForegroundSet(&sContext, ClrDarkBlue);
GrRectFill(&sContext, &sRect);
// Put a white box around the banner.
GrContextForegroundSet(&sContext, ClrWhite);
GrRectDraw(&sContext, &sRect);
// Put the application name in the middle of the banner.
GrContextFontSet(&sContext, &g_sFontCm20);
GrStringDrawCentered(&sContext, "Pressure Mesurement", -1,
GrContextDpyWidthGet(&sContext) / 2, 10, 0);
// Configure and enable uDMA
SysCtlPeripheralEnable(SYSCTL_PERIPH_UDMA);
SysCtlDelay(10);
uDMAControlBaseSet(&sDMAControlTable[0]);
uDMAEnable();
// Initialize the touch screen driver and have it route its messages to the
// widget tree.
TouchScreenInit();
TouchScreenCallbackSet(WidgetPointerMessage);
// Add the title block and the previous and next buttons to the widget
// tree.
WidgetAdd(WIDGET_ROOT, (tWidget *)&g_sPrevious);
WidgetAdd(WIDGET_ROOT, (tWidget *)&g_sTitle);
WidgetAdd(WIDGET_ROOT, (tWidget *)&g_sNext);
// Add the first panel to the widget tree.
g_ulPanel = 0;
WidgetAdd(WIDGET_ROOT, (tWidget *)g_psPanels);
CanvasTextSet(&g_sTitle, g_pcPanelNames[0]);
// Issue the initial paint request to the widgets.
WidgetPaint(WIDGET_ROOT);
// Loop forever handling widget messages.
while(1)
// Process any messages in the widget message queue.
WidgetMessageQueueProcess();
void ADC1SS3_Handler(void)
char str[10];
uint32_t n;
tRectangle sRect;
ADC1_ISC_R = 0x00000008;
ADCvalue = ADC0_SSFIFO3_R & ADC_SSFIFO3_DATA_M; // aquisition de la tension
n=usprintf(str, "%u", ADCvalue);
CanvasTextSet(g_psText, str);
//REFRESH DISPLAY
