Other Parts Discussed in Thread: TMS570LC4357, HALCOGEN
Hi TI,
I am using TMS570LC4357. I wants to integrate HALCoGen Ethernet Driver and lwIP Integration Demonstration Library to establish a UDP communication. I have downloaded the Demo Code from
I had also read the lwip.pdf for using lwIP API for UDP communication. In that PDF, they given the example code only for the TCP/IP server configuration. So I copied that code and paste it in the ethernet demo project given in the CCS environment.
Unfortunately when I try to build it, shows lot of errors.
Please anybody guide me to use this library for establishing UDP communication or else TCP/IP communication atleast with the available example code in lwip.pdf which is located in C:\ti\Hercules\HALCoGen EMAC Driver with lwIP Demonstration\v00.03.00\lwip-1.4.1\doc\lwip.pdf.
Expecting your guidance.
Thanks in advance.
Karthikeyan.K
