Hello, I wanted to consult about a problem I'm having with the management of MPU9150 (I have not BoosterPack IT). I'm working on CCS v5 with stellaris launchpad. Basically, I was trying to get console data (raw data from the accelerometer, gyroscope and magnetometer sensor). To do this, I tested modifying one of the examples of TivaWare (compdcm_mpu9150), only annulling the part of graphing LCD. The code buid without problems, but when I debbuging, fall into a FaultISR . With some breakpoints I can see this happening right in the command "GPIOPinConfigure (GPIO_PA0_U0RX);" and when I step into this function I see that the fault occurs in "HWREG (ulBase + GPIO_O_PCTL) = ((HWREG (ulBase + GPIO_O_PCTL) & ~ (0xf << ulShift)) | ((ulPinConfig & 0xf) << ulShift)) ; " function. Any suggestions or correction?
// compdcm_mpu9150.c - Example to demonstrate the use of the SensorLib with the
// MPU9150
// Copyright (c) 2013-2014 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.0.12573 of the DK-TM4C129X Firmware Package.
#include <stdint.h>
#include <stdbool.h>
#include "inc/hw_memmap.h"
#include "inc/hw_ints.h"
#include "inc/hw_types.h"
#include "inc/hw_i2c.h"
#include "driverlib/sysctl.h"
#include "driverlib/debug.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/pin_map.h"
#include "driverlib/rom.h"
#include "driverlib/rom_map.h"
#include "driverlib/uart.h"
#include "driverlib/i2c.h"
//#include "grlib/grlib.h"
//#include "drivers/frame.h"
//#include "drivers/kentec320x240x16_ssd2119.h"
//#include "drivers/pinout.h"
#include "utils/uartstdio.h"
#include "utils/ustdlib.h"
#include "sensorlib/hw_mpu9150.h"
#include "sensorlib/hw_ak8975.h"
#include "sensorlib/i2cm_drv.h"
#include "sensorlib/ak8975.h"
#include "sensorlib/mpu9150.h"
#include "sensorlib/comp_dcm.h"
//! \addtogroup example_list
//! <h1>Nine Axis Sensor Fusion with the MPU9150 and Complimentary-Filtered
//! DCM (compdcm_mpu9150)</h1>
//! This example demonstrates the basic use of the Sensor Library, DK-TM4C129X
//! and SensHub BoosterPack to obtain nine axis motion measurements from the
//! MPU9150. The example fuses the nine axis measurements into a set of Euler
//! angles: roll, pitch and yaw. It also produces the rotation quaternions.
//! The fusion mechanism demonstrated is complimentary-filtered direct cosine
//! matrix (DCM) algorithm that is provided as part of the Sensor Library.
//! The raw sensor measurements, Euler angles and quaternions are printed to
//! LCD and terminal. Connect a serial terminal program to the DK-TM4C129X's
//! ICDI virtual serial port at 115,200 baud. Use eight bits per byte, no
//! parity and one stop bit. The blue LED blinks to indicate the code is
//! running.
// Define MPU9150 I2C Address.
#define MPU9150_I2C_ADDRESS 0x68
// Structure to hold the graphics context.
//tContext g_sContext;
// Global instance structure for the I2C master driver.
tI2CMInstance g_sI2CInst;
// Global instance structure for the MPU9150 sensor driver.
tMPU9150 g_sMPU9150Inst;
// Global Instance structure to manage the DCM state.
tCompDCM g_sCompDCMInst;
// Global flags to alert main that MPU9150 I2C transaction is complete
volatile uint_fast8_t g_vui8I2CDoneFlag;
// Global flags to alert main that MPU9150 I2C transaction error has occurred.
volatile uint_fast8_t g_vui8ErrorFlag;
// Global flags to alert main that MPU9150 data is ready to be retrieved.
volatile uint_fast8_t g_vui8DataFlag;
// Compute Y-coordinate (of the LCD) for the required line. The variable
// ui32TextHeight must be assigned with the height of the current font before
// calling this macro.
// #define Line(n) (27 + (n * (ui32TextHeight + 5)))
// Global counter to control and slow down the rate of data to the terminal.
#define PRINT_SKIP_COUNT 10
uint32_t g_ui32PrintSkipCounter;
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, uint32_t ui32Line)
#endif
static void i2c_configure(void){
// Habilito los GPIOs del puerto A (ya que voy a usar A6 y A7)
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
// Habilito el perisferico I2C1
SysCtlPeripheralEnable(SYSCTL_PERIPH_I2C1);
// Configuro la multiplexacion de pines para las funciones del I2C
GPIOPinConfigure(GPIO_PA6_I2C1SCL);
GPIOPinConfigure(GPIO_PA7_I2C1SDA);
// Selecciona las funciones de I2C para estos pines
GPIOPinTypeI2C(GPIO_PORTA_BASE, GPIO_PIN_6 | GPIO_PIN_7);
static void uart_configure(void){
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
GPIOPinConfigure(GPIO_PA0_U0RX);
GPIOPinConfigure(GPIO_PA1_U0TX);
GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
/* UARTConfigSetExpClk(UART0_BASE, SysCtlClockGet(), 115200,
(UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |
UART_CONFIG_PAR_NONE));*/
// Contiene al UARTConfigSetExpClk, solo que a una configuración fija.
UARTStdioConfig(0, 115200, SysCtlClockGet());
// MPU9150 Sensor callback function. Called at the end of MPU9150 sensor
// driver transactions. This is called from I2C interrupt context. Therefore,
// we just set a flag and let main do the bulk of the computations and display.
void
MPU9150AppCallback(void *pvCallbackData, uint_fast8_t ui8Status)
// If the transaction succeeded set the data flag to indicate to
// application that this transaction is complete and data may be ready.
if(ui8Status == I2CM_STATUS_SUCCESS)
g_vui8I2CDoneFlag = 1;
// Store the most recent status in case it was an error condition
g_vui8ErrorFlag = ui8Status;
// Called by the NVIC as a result of GPIO port S interrupt event. For this
// application GPIO port S pin 2 is the interrupt line for the MPU9150.
void
GPIOFIntHandler(void)
unsigned long ulStatus;
ulStatus = GPIOPinIntStatus(GPIO_PORTF_BASE, true);
// Clear all the pin interrupts that are set
GPIOPinIntClear(GPIO_PORTF_BASE, ulStatus);
if(ulStatus & GPIO_PIN_1)
// MPU9150 Data is ready for retrieval and processing.
MPU9150DataRead(&g_sMPU9150Inst, MPU9150AppCallback, &g_sMPU9150Inst);
// Called by the NVIC as a result of I2C3 Interrupt. I2C3 is the I2C connection
// to the MPU9150.
void
MPU9150I2CIntHandler(void)
// Pass through to the I2CM interrupt handler provided by sensor library.
// This is required to be at application level so that I2CMIntHandler can
// receive the instance structure pointer as an argument.
I2CMIntHandler(&g_sI2CInst);
// MPU9150 Application error handler. Show the user if we have encountered an
// I2C error.
void
MPU9150AppErrorHandler(char *pcFilename, uint_fast32_t ui32Line)
// Set terminal color to red and print error status and locations
UARTprintf("\033[31;1m");
UARTprintf("Error: %d, File: %s, Line: %d\n"
"See I2C status definitions in sensorlib\\i2cm_drv.h\n",
g_vui8ErrorFlag, pcFilename, ui32Line);
// Return terminal color to normal
UARTprintf("\033[0m");
// Go to sleep wait for interventions. A more robust application could
// attempt corrective actions here.
while(1)
// Do Nothing
// Function to wait for the MPU9150 transactions to complete. Use this to spin
// wait on the I2C bus.
void
MPU9150AppI2CWait(char *pcFilename, uint_fast32_t ui32Line)
// Put the processor to sleep while we wait for the I2C driver to
// indicate that the transaction is complete.
while((g_vui8I2CDoneFlag == 0) && (g_vui8ErrorFlag == 0))
// Do Nothing
// If an error occurred call the error handler immediately.
if(g_vui8ErrorFlag)
MPU9150AppErrorHandler(pcFilename, ui32Line);
// clear the data flag for next use.
g_vui8I2CDoneFlag = 0;
// Main application entry point.
int
main(void)
int_fast32_t i32IPart[16], i32FPart[16];
uint_fast32_t ui32SysClock, ui32Idx, ui32CompDCMStarted;
float pfData[16];
float *pfAccel, *pfGyro, *pfMag, *pfEulers, *pfQuaternion;
// Initialize convenience pointers that clean up and clarify the code
// meaning. We want all the data in a single contiguous array so that
// we can make our pretty printing easier later.
pfAccel = pfData;
pfGyro = pfData + 3;
pfMag = pfData + 6;
pfEulers = pfData + 9;
pfQuaternion = pfData + 12;
// Setup the system clock to run at 40 Mhz from PLL with crystal reference
SysCtlClockSet(SYSCTL_SYSDIV_5|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
ui32SysClock = SysCtlClockGet();
// Configure the device pins.
// PinoutSet();
// Enable UART0
uart_configure();
// Print the welcome message to the terminal.
UARTprintf("\033[2JMPU9150 Raw Example\n");
i2c_configure();
// Configure and Enable the GPIO interrupt. Used for INT signal from the
// MPU9150
GPIOPinTypeGPIOInput(GPIO_PORTF_BASE, GPIO_PIN_1);
GPIOPinIntEnable(GPIO_PORTF_BASE, GPIO_PIN_1);
GPIOIntTypeSet(GPIO_PORTF_BASE, GPIO_PIN_1, GPIO_FALLING_EDGE);
IntEnable(INT_GPIOF);
// Keep only some parts of the systems running while in sleep mode.
// GPIOS is for the MPU9150 interrupt pin.
// UART0 is the virtual serial port.
// I2C3 is the I2C interface to the ISL29023.
SysCtlPeripheralClockGating(true);
SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_GPIOF);
SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_UART0);
SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_I2C1);
// Enable interrupts to the processor.
IntMasterEnable();
// Initialize I2C1 peripheral.
I2CMInit(&g_sI2CInst, I2C1_MASTER_BASE, INT_I2C1, 0xff, 0xff,
ui32SysClock);
SysCtlDelay(SysCtlClockGet() / 3); // Adherido por mi. Espera para que se resuleva algún problema con el I2C (en caso de que haya habido)
// I2CMasterInitExpClk(I2C1_MASTER_BASE, SysCtlClockGet(), true);
// Initialize the MPU9150 Driver.
MPU9150Init(&g_sMPU9150Inst, &g_sI2CInst, MPU9150_I2C_ADDRESS,
// Wait for transaction to complete
MPU9150AppI2CWait(__FILE__, __LINE__);
// Write application specifice sensor configuration such as filter settings
// and sensor range settings.
g_sMPU9150Inst.pui8Data[0] = MPU9150_CONFIG_DLPF_CFG_94_98;
g_sMPU9150Inst.pui8Data[1] = MPU9150_GYRO_CONFIG_FS_SEL_250;
g_sMPU9150Inst.pui8Data[2] = (MPU9150_ACCEL_CONFIG_ACCEL_HPF_5HZ |
MPU9150_ACCEL_CONFIG_AFS_SEL_2G);
MPU9150Write(&g_sMPU9150Inst, MPU9150_O_CONFIG, g_sMPU9150Inst.pui8Data, 3,
// Configure the data ready interrupt pin output of the MPU9150.
g_sMPU9150Inst.pui8Data[0] = MPU9150_INT_PIN_CFG_INT_LEVEL |
MPU9150_INT_PIN_CFG_INT_RD_CLEAR |
MPU9150_INT_PIN_CFG_LATCH_INT_EN;
g_sMPU9150Inst.pui8Data[1] = MPU9150_INT_ENABLE_DATA_RDY_EN;
MPU9150Write(&g_sMPU9150Inst, MPU9150_O_INT_PIN_CFG,
g_sMPU9150Inst.pui8Data, 2, MPU9150AppCallback,
&g_sMPU9150Inst);
// Initialize the DCM system. 50 hz sample rate.
// accel weight = .2, gyro weight = .8, mag weight = .2
CompDCMInit(&g_sCompDCMInst, 1.0f / 50.0f, 0.2f, 0.6f, 0.2f);
// Configure PQ4 to control the blue LED.
//MAP_GPIOPinTypeGPIOOutput(GPIO_PORTQ_BASE, GPIO_PIN_4);
// Print the table to be displayed on the UART terminal.
UARTprintf("\033[2J\033[H");
UARTprintf("MPU9150 9-Axis Simple Data Application Example\n\n");
UARTprintf("\033[20GX\033[31G|\033[43GY\033[54G|\033[66GZ\n\n");
UARTprintf("Accel\033[8G|\033[31G|\033[54G|\n\n");
UARTprintf("Gyro\033[8G|\033[31G|\033[54G|\n\n");
UARTprintf("Mag\033[8G|\033[31G|\033[54G|\n\n");
UARTprintf("\n\033[20GRoll\033[31G|\033[43GPitch\033[54G|\033[66GYaw\n\n");
UARTprintf("Eulers\033[8G|\033[31G|\033[54G|\n\n");
UARTprintf("\n\033[17GQ1\033[26G|\033[35GQ2\033[44G|\033[53GQ3\033[62G|"
"\033[71GQ4\n\n");
UARTprintf("Q\033[8G|\033[26G|\033[44G|\033[62G|\n\n");
ui32CompDCMStarted = 0;
while(1)
// Go to sleep mode while waiting for data ready.
while(!g_vui8I2CDoneFlag)
MAP_SysCtlSleep();
// Clear the flag
// Get floating point version of the Accel Data in m/s^2.
MPU9150DataAccelGetFloat(&g_sMPU9150Inst, pfAccel, pfAccel + 1,
pfAccel + 2);
// Get floating point version of angular velocities in rad/sec
MPU9150DataGyroGetFloat(&g_sMPU9150Inst, pfGyro, pfGyro + 1,
pfGyro + 2);
// Get floating point version of magnetic fields strength in tesla
MPU9150DataMagnetoGetFloat(&g_sMPU9150Inst, pfMag, pfMag + 1,
pfMag + 2);
// Check if this is our first data ever.
if(ui32CompDCMStarted == 0)
// Set flag indicating that DCM is started.
// Perform the seeding of the DCM with the first data set.
ui32CompDCMStarted = 1;
CompDCMMagnetoUpdate(&g_sCompDCMInst, pfMag[0], pfMag[1],
pfMag[2]);
CompDCMAccelUpdate(&g_sCompDCMInst, pfAccel[0], pfAccel[1],
pfAccel[2]);
CompDCMGyroUpdate(&g_sCompDCMInst, pfGyro[0], pfGyro[1],
pfGyro[2]);
CompDCMStart(&g_sCompDCMInst);
else
// DCM Is already started. Perform the incremental update.
pfMag[2]);
pfAccel[2]);
CompDCMGyroUpdate(&g_sCompDCMInst, -pfGyro[0], -pfGyro[1],
-pfGyro[2]);
CompDCMUpdate(&g_sCompDCMInst);
// Increment the skip counter. Skip counter is used so we do not
// overflow the UART with data.
g_ui32PrintSkipCounter++;
if(g_ui32PrintSkipCounter >= PRINT_SKIP_COUNT)
// Reset skip counter.
g_ui32PrintSkipCounter = 0;
// Blink the blue LED to indicate activity.
MAP_GPIOPinWrite(GPIO_PORTQ_BASE, GPIO_PIN_4,
((GPIOPinRead(GPIO_PORTQ_BASE, GPIO_PIN_4)) ^
GPIO_PIN_4));
// Get Euler data. (Roll Pitch Yaw)
CompDCMComputeEulers(&g_sCompDCMInst, pfEulers, pfEulers + 1,
pfEulers + 2);
// Get Quaternions.
CompDCMComputeQuaternion(&g_sCompDCMInst, pfQuaternion);
// convert mag data to micro-tesla for better human interpretation.
pfMag[0] *= (float)1e6;
pfMag[1] *= (float)1e6;
pfMag[2] *= (float)1e6;
// Convert Eulers to degrees. 180/PI = 57.29...
// Convert Yaw to 0 to 360 to approximate compass headings.
pfEulers[0] *= 57.295779513082320876798154814105f;
pfEulers[1] *= 57.295779513082320876798154814105f;
pfEulers[2] *= 57.295779513082320876798154814105f;
if(pfEulers[2] < 0)
pfEulers[2] += 360.0f;
// Now drop back to using the data as a single array for the
// purpose of decomposing the float into a integer part and a
// fraction (decimal) part.
for(ui32Idx = 0; ui32Idx < 16; ui32Idx++)
// Conver float value to a integer truncating the decimal part.
i32IPart[ui32Idx] = (int32_t) pfData[ui32Idx];
// Multiply by 1000 to preserve first three decimal values.
// Truncates at the 3rd decimal place.
i32FPart[ui32Idx] = (int32_t) (pfData[ui32Idx] * 1000.0f);
// Subtract off the integer part from this newly formed decimal
// part.
i32FPart[ui32Idx] = i32FPart[ui32Idx] -
(i32IPart[ui32Idx] * 1000);
// make the decimal part a positive number for display.
if(i32FPart[ui32Idx] < 0)
i32FPart[ui32Idx] *= -1;
// Print the acceleration numbers to the table on LCD and terminal.
/*usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[0], i32FPart[0]);
GrStringDraw(&g_sContext, pcBuf, 8, (97 - 32), Line(2), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[1], i32FPart[1]);
GrStringDraw(&g_sContext, pcBuf, 8, (182 - 32), Line(2), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[2], i32FPart[2]);
GrStringDraw(&g_sContext, pcBuf, 8, (267 - 32), Line(2), 1);*/
UARTprintf("\033[5;17H%3d.%03d", i32IPart[0], i32FPart[0]);
UARTprintf("\033[5;40H%3d.%03d", i32IPart[1], i32FPart[1]);
UARTprintf("\033[5;63H%3d.%03d", i32IPart[2], i32FPart[2]);
// Print the angular velocities to the table on LCD and terminal.
/*usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[3], i32FPart[3]);
GrStringDraw(&g_sContext, pcBuf, 8, (97 - 32), Line(3), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[4], i32FPart[4]);
GrStringDraw(&g_sContext, pcBuf, 8, (182 - 32), Line(3), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[5], i32FPart[5]);
GrStringDraw(&g_sContext, pcBuf, 8, (267 - 32), Line(3), 1);*/
UARTprintf("\033[7;17H%3d.%03d", i32IPart[3], i32FPart[3]);
UARTprintf("\033[7;40H%3d.%03d", i32IPart[4], i32FPart[4]);
UARTprintf("\033[7;63H%3d.%03d", i32IPart[5], i32FPart[5]);
// Print the magnetic data to the table on LCD and terminal.
/*usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[6], i32FPart[6]);
GrStringDraw(&g_sContext, pcBuf, 8, (97 - 32), Line(4), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[7], i32FPart[7]);
GrStringDraw(&g_sContext, pcBuf, 8, (182 - 32), Line(4), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[8], i32FPart[8]);
GrStringDraw(&g_sContext, pcBuf, 8, (267 - 32), Line(4), 1);*/
UARTprintf("\033[9;17H%3d.%03d", i32IPart[6], i32FPart[6]);
UARTprintf("\033[9;40H%3d.%03d", i32IPart[7], i32FPart[7]);
UARTprintf("\033[9;63H%3d.%03d", i32IPart[8], i32FPart[8]);
// Print the Eulers to the table on LCD and terminal.
/*usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[9], i32FPart[9]);
GrStringDraw(&g_sContext, pcBuf, 8, (97 - 32), Line(6), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[10], i32FPart[10]);
GrStringDraw(&g_sContext, pcBuf, 8, (182 - 32), Line(6), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[11], i32FPart[12]);
GrStringDraw(&g_sContext, pcBuf, 8, (267 - 32), Line(6), 1);*/
UARTprintf("\033[14;17H%3d.%03d", i32IPart[9], i32FPart[9]);
UARTprintf("\033[14;40H%3d.%03d", i32IPart[10], i32FPart[10]);
UARTprintf("\033[14;63H%3d.%03d", i32IPart[11], i32FPart[11]);
// Print the quaternions to the table format on LCD and terminal.
/*usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[12], i32FPart[12]);
GrStringDraw(&g_sContext, pcBuf, 8, (87 - 32), Line(8), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[13], i32FPart[13]);
GrStringDraw(&g_sContext, pcBuf, 8, (151 - 32), Line(8), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[14], i32FPart[14]);
GrStringDraw(&g_sContext, pcBuf, 8, (215 - 32), Line(8), 1);
usnprintf(pcBuf, 15, "%3d.%03d ", i32IPart[15], i32FPart[15]);
GrStringDraw(&g_sContext, pcBuf, 8, (279 - 32), Line(8), 1);*/
UARTprintf("\033[19;14H%3d.%03d", i32IPart[12], i32FPart[12]);
UARTprintf("\033[19;32H%3d.%03d", i32IPart[13], i32FPart[13]);
UARTprintf("\033[19;50H%3d.%03d", i32IPart[14], i32FPart[14]);
UARTprintf("\033[19;68H%3d.%03d", i32IPart[15], i32FPart[15]);
Jose
