Other Parts Discussed in Thread: TMS570LC4357
Hello ,
I have To implement Manchester Encoding of 20KHz Using N2HET in TMS570LC4357.
I need Clarifications on below points:
1) Is There a method or Instruction to check HET pin Status in HET Program (HET Assembler Code).
2) Is it possible to set/clear the HET pin HET Program(HET Assembler Code) .
3) How we can Assign the Data Field of HET Instrcution to a variable, So that it can be changed during Run time from Application code.
