Hello, I am trying this below code to transfer Data from EPI(C0000000) to sram memory.
I am able to debug it but its not writing any thing to memory.Any corrections to be made in code please suggest................
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
#include <stdbool.h>
#include "inc/hw_types.h"
#include "inc/hw_epi.h"
#include "inc/hw_memmap.h"
#include "inc/hw_nvic.h"
#include "inc/hw_ints.h"
#include "inc/hw_uart.h"
#include "inc/hw_gpio.h"
#include "driverlib/flash.h"
#include "driverlib/gpio.h"
#include "drivers/pinout.h"
#include "driverlib/pin_map.h"
#include "driverlib/rom.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "driverlib/rom_map.h"
#include "driverlib/uart.h"
#include "driverlib/udma.h"
#include "utils/uartstdio.h"
#include "driverlib/epi.h"
#include "driverlib/interrupt.h"
#include "driverlib/debug.h"
#include "driverlib/timer.h"
#include "utils/ustdlib.h"
// Defines for setting up the system clock.
#define SYSTICKHZ 100
#define SYSTICKMS (1000 / SYSTICKHZ)
// The system clock frequency.
uint32_t g_ui32SysClock;
// The starting and ending address for the 8MB SDRAM chip (4Meg x 16bits) on
// the SDRAM daughter board.
#define SDRAM_START_ADDRESS 0x000000
#define SDRAM_END_ADDRESS 0x3FFFFF
// The control table used by the uDMA controller. This table must be aligned
// to a 1024 byte boundary.
#if defined(ewarm)
#pragma data_alignment=1024
unsigned char ucControlTable[1024];
#elif defined(ccs)
#pragma DATA_ALIGN(ucControlTable, 1024)
#else
unsigned char ucControlTable[1024] __attribute__ ((aligned(1024)));
#endif
// A pointer to the EPI memory aperture. Note that g_pusEPISdram is declared
// as volatile so the compiler should not optimize reads out of the image.
static volatile unsigned short *g_pusEPISdram;
// A global to hold the value to be transfered to the sdram.
static volatile unsigned short g_pusTxData[1];
// Variable to hold the count of the number of uDMA errors.
static volatile unsigned long g_uluDMAErrorCount;
// Variable to hold the count of the number of completed uDMA transfers.
static volatile unsigned long g_uluDMACompleted;
// This function sets up UART0 to be used for a console to display information
// as the example is running.
void
InitConsole(void)
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
GPIOPinConfigure(GPIO_PA0_U0RX);
GPIOPinConfigure(GPIO_PA1_U0TX);
GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
// Initialize the UART for console I/O.
UARTStdioConfig(0, 115200, g_ui32SysClock);
// The interrupt handler for uDMA errors. This interrupt will occur if the
// uDMA encounters a bus error while trying to perform a transfer. This
// handler just increments a counter if an error occurs.
void
uDMAErrorHandler(void)
unsigned long ulStatus;
// Check for uDMA error bit
ulStatus = uDMAErrorStatusGet();
// If there is a uDMA error, then clear the error and increment
// the error counter.
if(ulStatus)
uDMAErrorStatusClear();
g_uluDMAErrorCount++;
// Configure the uDMA transfers to the EPI sdram.
void
InitEPITransfer(void)
// Disable the attributes.
uDMAChannelAttributeDisable(UDMA_SEC_CHANNEL_EPI0TX,
UDMA_ATTR_ALTSELECT |
UDMA_ATTR_USEBURST |
UDMA_ATTR_HIGH_PRIORITY |
UDMA_ATTR_REQMASK);
uDMAChannelAttributeEnable(UDMA_SEC_CHANNEL_EPI0TX, UDMA_ATTR_USEBURST);
// Use the secondary channel - EPI0TX
uDMAChannelSelectSecondary(UDMA_DEF_TMR1B_SEC_EPI0TX);
// Setup the uDMA channel.
// Send 16-bit data, do not increment the source, increment the SDRAM
// memory by 16 bits, and by setting arbitration size to one the uDMA
// engine will rearbitrate after one item gets transfered.
uDMAChannelControlSet(UDMA_SEC_CHANNEL_EPI0TX,
UDMA_SIZE_16 |
UDMA_SRC_INC_NONE |
UDMA_DST_INC_16 |
UDMA_ARB_1);
int CTI_EPI_Init() {
//**************** Enable EPI0********************//
SysCtlPeripheralEnable(SYSCTL_PERIPH_EPI0);
//**************Configure EPIO********************//
EPIDividerSet(EPI0_BASE, 0);
EPIModeSet(EPI0_BASE, EPI_MODE_GENERAL);
EPIConfigGPModeSet(EPI0_BASE,
EPI_GPMODE_DSIZE_16 | EPI_GPMODE_ASIZE_12 | EPI_GPMODE_CLKPIN, 0,
0);
EPIAddressMapSet(EPI0_BASE, EPI_ADDR_PER_BASE_C | EPI_ADDR_PER_SIZE_64KB);
EPIFIFOConfig(EPI0_BASE,
(EPI_FIFO_CONFIG_TX_EMPTY | EPI_FIFO_CONFIG_RX_1_4
| EPI_FIFO_CONFIG_RSTALLERR));
IntEnable(INT_EPI0);
// Configure GPIO Ports and Pins
GPIOPinConfigure(GPIO_PB3_EPI0S28); //WR
GPIOPinConfigure(GPIO_PP2_EPI0S29); //RD
GPIOPinConfigure(GPIO_PK0_EPI0S0); //D0
GPIOPinConfigure(GPIO_PK1_EPI0S1); //D1
GPIOPinConfigure(GPIO_PK2_EPI0S2); //D2
GPIOPinConfigure(GPIO_PK3_EPI0S3); //D3
GPIOPinConfigure(GPIO_PC7_EPI0S4); //D4
GPIOPinConfigure(GPIO_PC6_EPI0S5); //D5
GPIOPinConfigure(GPIO_PC5_EPI0S6); //D6
GPIOPinConfigure(GPIO_PC4_EPI0S7); //D7
GPIOPinConfigure(GPIO_PA6_EPI0S8); //D8
GPIOPinConfigure(GPIO_PA7_EPI0S9); //D9
GPIOPinConfigure(GPIO_PG1_EPI0S10); //D10
GPIOPinConfigure(GPIO_PG0_EPI0S11); //D11
GPIOPinConfigure(GPIO_PM3_EPI0S12); //D12
GPIOPinConfigure(GPIO_PM2_EPI0S13); //D13
GPIOPinConfigure(GPIO_PM1_EPI0S14); //D14
GPIOPinConfigure(GPIO_PM0_EPI0S15); //D15
GPIOPinConfigure(GPIO_PL0_EPI0S16); //A0
GPIOPinConfigure(GPIO_PL1_EPI0S17); //A1
GPIOPinConfigure(GPIO_PL2_EPI0S18); //A2
GPIOPinConfigure(GPIO_PL3_EPI0S19); //A3
GPIOPinConfigure(GPIO_PQ0_EPI0S20); //A4
GPIOPinConfigure(GPIO_PQ1_EPI0S21); //A5
GPIOPinConfigure(GPIO_PQ2_EPI0S22); //A6
GPIOPinConfigure(GPIO_PQ3_EPI0S23); //A7
GPIOPinConfigure(GPIO_PK7_EPI0S24); //A8
GPIOPinConfigure(GPIO_PK6_EPI0S25); //A9
GPIOPinConfigure(GPIO_PL4_EPI0S26); //A10
GPIOPinConfigure(GPIO_PB2_EPI0S27); //A11
GPIOPinConfigure(GPIO_PP3_EPI0S30); //FRAME
GPIOPinConfigure(GPIO_PK5_EPI0S31); //CLK
GPIOPinTypeEPI(GPIO_PORTA_BASE, 0xC0);
GPIOPinTypeEPI(GPIO_PORTB_BASE, 0x0C);
GPIOPinTypeEPI(GPIO_PORTC_BASE, 0xF0);
GPIOPinTypeEPI(GPIO_PORTG_BASE, 0x03);
GPIOPinTypeEPI(GPIO_PORTK_BASE, 0xEF);
GPIOPinTypeEPI(GPIO_PORTL_BASE, 0x1F);
GPIOPinTypeEPI(GPIO_PORTM_BASE, 0x0F);
GPIOPinTypeEPI(GPIO_PORTP_BASE, 0x0C);
GPIOPinTypeEPI(GPIO_PORTQ_BASE, 0x0F);
GPIOPadConfigSet(GPIO_PORTA_BASE, 0xC0, GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD);
GPIOPadConfigSet(GPIO_PORTB_BASE, 0x0C, GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD);
GPIOPadConfigSet(GPIO_PORTC_BASE, 0xF0, GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD);
GPIOPadConfigSet(GPIO_PORTG_BASE, 0x03, GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD);
GPIOPadConfigSet(GPIO_PORTK_BASE, 0xEF, GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD);
GPIOPadConfigSet(GPIO_PORTL_BASE, 0x1F, GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD);
GPIOPadConfigSet(GPIO_PORTM_BASE, 0x0F, GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD);
GPIOPadConfigSet(GPIO_PORTP_BASE, 0x0C, GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD);
GPIOPadConfigSet(GPIO_PORTQ_BASE, 0x0F, GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD);
GPIODirModeSet(GPIO_PORTA_BASE, 0xC0, GPIO_DIR_MODE_HW);
GPIODirModeSet(GPIO_PORTB_BASE, 0x0C, GPIO_DIR_MODE_HW);
GPIODirModeSet(GPIO_PORTC_BASE, 0xF0, GPIO_DIR_MODE_HW);
GPIODirModeSet(GPIO_PORTG_BASE, 0x03, GPIO_DIR_MODE_HW);
GPIODirModeSet(GPIO_PORTK_BASE, 0xEF, GPIO_DIR_MODE_HW);
GPIODirModeSet(GPIO_PORTL_BASE, 0x1F, GPIO_DIR_MODE_HW);
GPIODirModeSet(GPIO_PORTM_BASE, 0x0F, GPIO_DIR_MODE_HW);
GPIODirModeSet(GPIO_PORTP_BASE, 0x0C, GPIO_DIR_MODE_HW);
GPIODirModeSet(GPIO_PORTQ_BASE, 0x0F, GPIO_DIR_MODE_HW);
return 0;
//***********Enable all GPIO BANKS**************//
CTI_EPI_Enable_GPIO_Bank() {
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOG);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOK);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOL);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOM);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOP);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOQ);
/***************Disable all unused Peripherals*******************/
void CTI_Disable_UnsedDev() {
SysCtlPeripheralDisable(SYSCTL_PERIPH_CAN0);
SysCtlPeripheralDisable(SYSCTL_PERIPH_CAN1);
SysCtlPeripheralDisable(SYSCTL_PERIPH_I2C0);
SysCtlPeripheralDisable(SYSCTL_PERIPH_I2C1);
SysCtlPeripheralDisable(SYSCTL_PERIPH_I2C2);
SysCtlPeripheralDisable(SYSCTL_PERIPH_I2C3);
SysCtlPeripheralDisable(SYSCTL_PERIPH_I2C4);
SysCtlPeripheralDisable(SYSCTL_PERIPH_I2C5);
SysCtlPeripheralDisable(SYSCTL_PERIPH_I2C6);
SysCtlPeripheralDisable(SYSCTL_PERIPH_I2C7);
SysCtlPeripheralDisable(SYSCTL_PERIPH_I2C8);
SysCtlPeripheralDisable(SYSCTL_PERIPH_I2C9);
SysCtlPeripheralDisable(SYSCTL_PERIPH_LCD0);
SysCtlPeripheralDisable(SYSCTL_PERIPH_SSI1);
SysCtlPeripheralDisable(SYSCTL_PERIPH_SSI2);
SysCtlPeripheralDisable(SYSCTL_PERIPH_SSI3);
SysCtlPeripheralDisable(SYSCTL_PERIPH_PWM0);
SysCtlPeripheralDisable(SYSCTL_PERIPH_PWM1);
SysCtlPeripheralDisable(SYSCTL_PERIPH_QEI0);
SysCtlPeripheralDisable(SYSCTL_PERIPH_QEI1);
SysCtlPeripheralDisable(SYSCTL_PERIPH_UART3);
SysCtlPeripheralDisable(SYSCTL_PERIPH_UART4);
SysCtlPeripheralDisable(SYSCTL_PERIPH_UART5);
SysCtlPeripheralDisable(SYSCTL_PERIPH_UART6);
SysCtlPeripheralDisable(SYSCTL_PERIPH_UART7);
SysCtlPeripheralDisable(SYSCTL_PERIPH_USB0);
SysCtlPeripheralDisable(SYSCTL_PERIPH_WDOG0);
SysCtlPeripheralDisable(SYSCTL_PERIPH_WDOG1);
SysCtlPeripheralDisable(SYSCTL_PERIPH_ADC0);
SysCtlPeripheralDisable(SYSCTL_PERIPH_ADC1);
SysCtlPeripheralDisable(SYSCTL_PERIPH_TIMER0);
SysCtlPeripheralDisable(SYSCTL_PERIPH_TIMER1);
SysCtlPeripheralDisable(SYSCTL_PERIPH_TIMER2);
SysCtlPeripheralDisable(SYSCTL_PERIPH_TIMER3);
SysCtlPeripheralDisable(SYSCTL_PERIPH_TIMER4);
SysCtlPeripheralDisable(SYSCTL_PERIPH_TIMER5);
SysCtlPeripheralDisable(SYSCTL_PERIPH_TIMER6);
SysCtlPeripheralDisable(SYSCTL_PERIPH_TIMER7);
SysCtlPeripheralDisable(SYSCTL_PERIPH_WTIMER0);
SysCtlPeripheralDisable(SYSCTL_PERIPH_WTIMER1);
SysCtlPeripheralDisable(SYSCTL_PERIPH_WTIMER2);
SysCtlPeripheralDisable(SYSCTL_PERIPH_WTIMER3);
SysCtlPeripheralDisable(SYSCTL_PERIPH_WTIMER4);
SysCtlPeripheralDisable(SYSCTL_PERIPH_WTIMER5);
// Configure EPI0 in SDRAM mode. The EPI memory space is setup using an a
// simple C array. This example shows how to read and write to an SDRAM card
// using the EPI bus in SDRAM mode.
int
main(void)
SysCtlMOSCConfigSet(SYSCTL_MOSC_HIGHFREQ);
// Set the device pinout appropriately for this board.
//PinoutSet();
// Run from the PLL at 120 MHz.
g_ui32SysClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
SYSCTL_OSC_MAIN | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480), 120000000);
// Set up the serial console to use for displaying messages. This is
// just for this example program and is not needed for EPI operation.
InitConsole();
CTI_EPI_Enable_GPIO_Bank();
CTI_Disable_UnsedDev();
UARTprintf("Initializing EPI\n");
CTI_EPI_Init();
// Enable the uDMA controller at the system level. Enable it to continue
// to run while the processor is in sleep.
SysCtlPeripheralEnable(SYSCTL_PERIPH_UDMA);
// Enable the uDMA controller.
uDMAEnable();
// Point at the control table to use for channel control structures.
uDMAControlBaseSet(ucControlTable);
// Initialize the uDMA EPI transfers.
InitEPITransfer();
g_uluDMACompleted = 0;
g_uluDMAErrorCount = 0;
// Enable the uDMA controller error interrupt. This interrupt will occur
// if there is a bus error during a transfer.
IntEnable(INT_UDMAERR);
// Enable interrupts from the uDMA channel.
IntEnable(INT_UDMA);
// Enable processor interrupts.
IntMasterEnable();
// Set the EPI memory pointer to the base of EPI memory space. Note that
// g_pusEPISdram is declared as volatile so the compiler should not
// optimize reads out of the memory. With this pointer, the memory space
// is accessed like a simple array.
g_pusEPISdram = (unsigned short *)0xC0000000;
// Setup the data to send.
g_pusTxData[0] = 0xabcd;
// Print the start message.
UARTprintf(" SDRAM Write:\n");
UARTprintf(" Mem[0xC000.0000] <- 0xabcd\n\n");
UARTprintf("-------------------------------\n\n");
// Setup the uDMA transder to the SDRAM on the EPI bus. Send one *item*
// using basic mode.
uDMAChannelTransferSet(UDMA_SEC_CHANNEL_EPI0TX,
UDMA_MODE_BASIC,
(void *)g_pusTxData,
(void *)g_pusEPISdram,
1);
uDMAChannelEnable(UDMA_SEC_CHANNEL_EPI0TX);
// Check for the primary control structure to indicate complete or exit
// if an error occurs.
while((uDMAChannelModeGet(UDMA_DEF_TMR1B_SEC_EPI0TX) != UDMA_MODE_STOP) &&
(g_uluDMAErrorCount == 0))
// Check for an error.
if(g_uluDMAErrorCount == 0)
// Indicate a successful transfer.
g_uluDMACompleted++;
// Print out the results.
UARTprintf(" Mem[0xC000.0000] = 0x%4x\n\n", g_pusEPISdram[SDRAM_START_ADDRESS]);
UARTprintf("g_uluDMACompleted = %d\n\rg_uluDMAErrorCount = %d",
g_uluDMACompleted, g_uluDMAErrorCount);
// Done. Wait in a loop forever.
while(1)
Krishnan
