LMFlash and UniFLash Really need EEPROM tools
Other Parts Discussed in Thread: UNIFLASH, LMFLASHPROGRAMMER
Guys:
I saw the thread that described various methods of downloading code or starting your image to program EEPROM. This is the first MCU product line I have seen that did not have a tool to program *all* writable media inside the IC.
Our situation is the same as the original poster in that thread:: our production line needs to program a unified Flash image (boot loader plus original application) *and* the EEPROM where configuration data is stored.
A lot of us would really appreciate your efforts to find a way to do the EEPROM programming from the JTAG running on a PC.
Thanks.
Ray
    Believe you raise a valid point - thanks for that.
    Might you "raise the odds" of this vendor's (initial) study and (later) compliance by "listing" the "top" two or three (others) which may serve as a "model" (and incentive) for this vendor?
    Anything which speeds/eases this vendor's efforts should prove to your, our (and this vendor's) advantage...
  • Hello Raymond,
    EEPROM was initially designed for Application Data Storage and was never meant to be pre loaded. But yes, I see the point of what-if there is a requirement. This while not supported on the LMFlashProgrammer nor UNIFLASH in a direct method, we have worked out a gel file that can be used to do the same. The same method may be done in dss script of UNIFLASH.
    Rather a long running post.
    e2e.ti.com/.../355823
    Amit
    And - unfortunately - a not, "too well marked/road-mapped" post - many would say.      (to include o.p. - who appears unaware of this particular, "nook/cranny!")
  • It appears Segger might support it through RAMCodes, it might be worth contacting them to see if they have existing support already.
    Robert
  • That's a good lead Robert - thanks.    Certain Segger tools do seem to require J-Link (fine for you/me) limiting perhaps for others, here...
  • I was looking to see if we could consolidate some of our JTAGs for other products to the J-Link.
    Yep, J-Link would be necessary but if there really is a significant production issue that's not much of a tooling cost.
    I don't know how many other vendors of ARM JTAGs still exist but there may be others out there with possible solutions as well.
    Robert
