Comments of CHECK_CRC are wrong
I've noticed the wrong comments in bl_main.c of the stellaris bootloader source.
#ifdef ENFORCE_CRC
                            if(ui32Retcode == CHECK_CRC_OK)
#else
                            if((ui32Retcode == CHECK_CRC_OK) ||
                               (ui32Retcode == CHECK_CRC_NO_LENGTH))
#endif
                                // The calculated CRC didn't match the expected
                                // value or the image didn't contain an embedded
                                // CRC.
                                g_ui8Status = COMMAND_RET_SUCCESS;
                            else
                                // The calculated CRC agreed with the embedded
                                // value.
                                g_ui8Status = COMMAND_RET_CRC_FAIL;
Best regards
Nicola Zaquini
