The relation between compiler and F021 Library.
Hello.
Can not using F021(Ver02.01.00) library in CCS5.4 Version and arm_5.1.1(TI v5.1.1) Compiler?
I tried the success, in CCS5.4 Version and arm_5.1.7(TI v5.1.7) Compiler.
Changed the only compiler at success the project.
(arm_5.1.7(TI v5.1.7) -> arm_5.1.1(TI v5.1.1)Compiler)
1727.build_1.txt
  • Your failure is not caused by compiler. Your linking option is wrong.
    "-l"F021_API_CortexR4_BE_V3D16.lib" "../F021 Flash API/02.01.00/F021_API_CortexM3_BE.lib" "../F021 Flash API/02.01.00/F021_API_CortexR4_BE.lib" "../F021 Flash API/02.01.00/F021_API_CortexR4_BE_L2FMC.lib" "../F021 Flash API/02.01.00/F021_API_CortexR4_BE_L2FMC_V3D16.lib" "../F021 Flash API/02.01.00/F021_API_CortexR4_BE_V3D16.lib" "../F021 Flash API/02.01.00/F021_API_CortexR4_LE.lib" "../F021 Flash API/02.01.00/F021_API_CortexR4_LE_L2FMC.lib" "../F021 Flash API/02.01.00/F021_API_CortexR4_LE_L2FMC_V3D16.lib" "../F021 Flash API/02.01.00/F021_API_CortexR4_LE_V3D16.lib""
    Why do you want link all Flash API libraries? You only need one.
    Thanks and regards,
    Zhaohong
