Other Parts Discussed in Thread: RM48L952
i want to use CAN for communicating my data to AM437x. is it advisable to use CAN. is there any additional hardware need to use between microcontroller (RM48) and Processor(AM437x)?
You need to have CAN transceiver on each side.
Thanks and regards,
Zhaohong
Thank you Mr.Zhaohong.
i have CAN Tx and Rx on both the sides. what about the communication cable. shall i use normal wires??? shall i directly connect Tx of hardware A(RM48L952) to Rx of Hardware B (AM437x)
regards
K.Manjunathan
i am using HDK(RM48L952). there is a CAN tranceiver IC (SN65HVD541) available in my HDK. other than this tranceiver ic any haedware needed??
You do not need any additional hardware on RM48 side. You need to check the HDK schematic to see which CAN module this transceiver is hooked.
Thanks and regards,
Zhaohong
