FatFS timing in usb_host_msc example code
The usb_host_msc example code for the TM4C129X dev kit implies that there is a tick counter requirement in order for FatFs to work.
In usb_host_msc.c the comments preceding the SysTickHandler() ISR say:
// This is the handler for this SysTick interrupt.  FatFs requires a
// timer tick every 10 ms for internal timing purposes.
The SysTickHandler() has a single line of code, which increments a tick counter:
void
SysTickHandler(void)
    // Update our tick counter.
    g_ui32SysTickCount++;
The only place g_ui32SysTickCount is referenced is in the GetTickms() function in usb_host_msc.c. But GetTickms() never gets called by any of the other code.
I looked at the FatFs online documentation, and cannot find any requirement for a tick count.
What is the purpose of the tick counter in this example code, and where can I find info regarding FatFs' need for a tick count?
Dave
