How I can check memory for read or write access?
If I read from nonexistent address of memory or flash I will get interrupt. How can check ability to read or write to memory to avoid errors?
  • Yes, you will get a data abort (for data fetch) or a prefetch abort (for instruction fetch) if you read from a memory location that does not exist or has been blocked from reading by the MPU. You need to write a prefetch abort handler and a data abort handler to address these cases.
    Sunil
