Other Parts Discussed in Thread: HALCOGEN, RM48L952, RM48L950
Hello
I got the TMDSRM48USB development kit now, and I am unable to finf any schematic diagram and sample examples.
Can anyone help me with proper links ?
Thanks in advance
Hello
Thanks in advance
Ankush,
Please follow detailed step-by-step instructions from the HALCoGen help menu. Click Help --> Help Topics. Then open the "Examples" category and choose the example_rtiBlinky.c file.
Let me know if you have any trouble following the instructions. This example toggles HET[0] pin, you can modify it to toggle whichever pin(s) you want.
Hello
I saw the CAN bus video on
I am not able to compile DCAN_RX program for RM48L950 USB kit
/** @file sys_main.c
* @brief Application main file
* @date 15.July.2015
* @version 04.05.00
* This file contains an empty main function,
* which can be used for the application.
* Copyright (C) 2009-2015 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
#include "sys_common.h"
#include "system.h"
#include "can.h"
#include "sci.h"
/* USER CODE END */
/* Include Files */
#include "system.h"
/* USER CODE BEGIN (1) */
/* USER CODE END */
/** @fn void main(void)
* @brief Application main function
* @note This function is empty by default.
* This function is called after startup.
* The user can use this function to implement the application.
/* USER CODE BEGIN (2) */
#define D_SIZE 9
uint8_t rx_data[D_SIZE]={0};
uint32_t error=0;
uint32_t checkPackets(uint8_t *src_packet, uint8_t *dst_packet, uint32_t psize);
/* USER CODE END */
void main(void)
/* USER CODE BEGIN (3) */
canInit();
sciInit();
while(!canIsRxMessageArrived(canREG1,canMESSAGE_BOX1));
canGetData(canREG1,canMESSAGE_BOX1,rx_data);
sciSend(scilinREG,D_SIZE,rx_data);
// error=checkPackets(&tx_data[0],&rx_data[0],D_SIZE);
while(1);
/* USER CODE END */
/* USER CODE BEGIN (4) */
uint32_t checkPackets(uint8_t *src_packet, uint8_t *dst_packet, uint32_t psize){
uint32_t err=0;
uint32_t cnt=psize;
while(cnt--){
if((*src_packet++)!=(*dst_packet++)){
err++;
return (err);
void canMessageNotification(canBASE_t *node,uint32_t messageBox){
return;
void canErrorNotification(canBASE_t *node,uint32_t notification){
return;
void esmGroup1Notification(unsigned channel){
return;
void esmGroup2Notification(unsigned channel){
return;
/* USER CODE END */
I am getting following error -
"tx_data is undefined"
Please help me how to solve this ?
