Other Parts Discussed in Thread: HALCOGEN
Sir.,
I tried to use a example program to generate PWM signal through HET.
Some error occurred. help me to sort it out.
attached the PDF file c
ontaining program and error JPEG image.
Sir.,
7245.NHET PWM generation and Capture using HALCoGen.pdfpdf file of PRogram
Hi Manjunath,
It looks like the source code in the pdf you have linked was written for an older version of Halcogen. You can replace "sys_esm.h" with "esm.h" and "nhet.h" with "het.h" and try running again. There may be other changes required as well. If you face further issues, I can take a look if you send the project file.
Vineeth
