I am trying to generate PWM without configuring HET in halcogen. I have written some codes will it work???
/** @file sys_main.c
* @brief Application main file
* @date 15.July.2015
* @version 04.05.00
* This file contains an empty main function,
* which can be used for the application.
* Copyright (C) 2009-2015 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "sys_common.h"
#include "het.h"
//#include "gio.h"
/* USER CODE BEGIN (1) */
/* USER CODE END */
/** @fn void main(void)
* @brief Application main function
* @note This function is empty by default.
* This function is called after startup.
* The user can use this function to implement the application.
///USER CODE BEGIN (2)
// USER CODE END */
hetSIGNAL_t Duty_Period1;
hetSIGNAL_t Set_Duty_Period1;
void main(void)
//int i;
//gioInit();
//gioSetDirection(hetPORT1, 0xBFFFFFFF); // 30 Input, 10 Output
//gioSetBit(hetPORT1, 10, 1);
//while(gioGetBit(hetPORT1, 30) == 0);
hetInit();
pwmStart(hetRAM1, pwm1);
Set_Duty_Period1.duty = 75;
Set_Duty_Period1.period = 2000;
pwmSetSignal(hetRAM1, pwm1, Set_Duty_Period1);
//unsigned int k;
//unsigned int i;
//while(1)
//for(i=0;i<100;i++)
//k=i*i;
/* USER CODE BEGIN (3) */
/* USER CODE END */
