On Flash
hi,
       i am currently working on the flash in the tm4c123gh6pge board .the main thing is,i want to read data from flash .so, what is the API for reading data from flash.
example:
for writing in to flash API is FlashProgram(unsigned int *pulData, unsigned int ulAddress, unsigned int ulCount);
for reading from flash API is...............................what?
  • for reading from flash API is...............................what?
    unsigned int    *pWordAddress;
    unsigned short  *pHWordAddress;
    unsigned char   *pCharAddress;
  • Hello Ravi,
    The flash is readable using the method f.m. has suggested or using HWREG(FLASH_ADDRESS) where FLASH_ADDRESS is value between 0x0-0x3FFFC
    Amit
  • I could have been more clear, but wanted the OP to think about it. An experienced person is aware of the "asymmetrical" nature of Flash/EEPROM. While erasing/writing requires relatively huge hardware and software efforts (hence the requirement of an API), reading is usually as simple as accessing a certain address. Some background knowledge does never hurt ...
