Purchase of Cortex R4 Board
Hi All,
A month back I purchased TMS570LS31HDK board. But we ended up in a situation where the codes are to be modified for big endian support.
Because of time lines, I am thinking to buy one more board, Hercules Development Kit for RM46 Hercules family series MCU's.
link : https://www.element14.com/community/docs/DOC-67649#overview
Can any body suggests better board to verify on Cortex R4? My major requirements are as follows:
1. Should have enough memories(> 3 MB RAM), 0~wait state memory reads/writes i.e. single cycle latency to memory reads/writes.
2. Should be able to use GCC compiled code.
3. Should have command line tools to control the board i.e. using either hyper terminal/tera term etc. This is basically for flashing the generated image, run and check the outputs.
4. Should have provision for memory reads/writes to the SD Card.
5. Should support little endian mode execution.
Thanks and Regards
 Sridhar
