Other Parts Discussed in Thread: EK-TM4C1294XL
Hello
I'm working with tm4c1294gxl
To check the functionality of sprintf() I have just copied the folder "Hello" from example code. & added all necessary files to run the code. & the code worked properly.
then I added and added following lines in the code at 1. original example code at the location "TI\examples\boards\ek-tm4c1294xl" as well as 2. in my new code location.
char str[10] ;
float a = -3.24;
sprintf(str, "%f", a);
UARTprintf("string = %f",str);
case 1 worked fine.
In case code gets hanged at " sprintf(str, "%f", a); " & if I comment " sprintf(str, "%f", a); " then I can see "string = ERROR " on serial monitor. Please let me know where I'm getting wrong.
attaching the code file here. the added code lines can be found from line no :134 to 139. remaining code is similar to "Hello" code from TI\examples\boards\ek-tm4c1294xl0181.hello.zip
