Other Parts Discussed in Thread: RM46L852
I downloaded the BXL file from ti.com and created the EDF file using UltraLibrarian as written in the instructions. Things are fine at this point, but when I import the EDF file using the EDF import option in OrCAD, I get a lot of errors in this vein...
Error: Location of object is wrong. Changed to (0,0)
The OLB file gets created anyway though, and Adding it into my opened libraries, works fine. Next when I try to use a part I get these error:
Internal Device Error: TextExtent returned unrealistic values.
U?A
U?A
U?A
U?A
RM4
RM46
RM46L
RM46L8
RM46L85
RM46L852
RM46L852_
RM46L852_P
RM46L852_PG
RM46L852_PGE
RM46L852_PGE_
RM46L852_PGE_1
RM46L852_PGE_14
RM46L852_PGE_144
RM46L852_PGE_144
The complete log is as follows:
EDIF2CAP('D:\UltraLibrarian\Library\Exported\Orcad\2016-05-23_14-34-34\2016-05-23_14-34-34.edf', 'D:\UltraLibrarian\Library\Exported\Orcad\2016-05-23_14-34-34\2016-05-23_14-34-34.DSN', 'D:\UltraLibrarian\Library\Exported\Orcad\2015-06-26_22-50-28\EDI@CAP.cfg')
Copyright (c) 2006-2011, Elgris Technologies, Inc.
Copyright (c) 1998-2005, Electronic Tools Company
EDIF 2 0 0 to OrCAD Capture Schematic Conversion Program SPB 16.50_1.086 built Jun 8 2011
Started on Mon May 23 14:49:54 2016
Reading config file D:\UltraLibrarian\Library\Exported\Orcad\2015-06-26_22-50-28\EDI@CAP.cfg
Processing EDIF 2 0 0 file D:\UltraLibrarian\Library\Exported\Orcad\2016-05-23_14-34-34\2016-05-23_14-34-34.edf
This EDIF file has unrecognized origin.
EDIF 200 parsing finished
Design has no schematics => OrCAD Schematic will not be created
Could not find F:\MY DOCUMENTS\TEXAS INSTRUMENTS\HERCULES\SPNM058\
Library D:\ULTRALIBRARIAN\LIBRARY\EXPORTED\ORCAD\2016-05-23_14-34-34\2016-05-23_14-34-34.OLB is created
Design Unit is equal to 0.00025400 mms
User pinSpacing is equal to : 0.00100000 mms
Calculated grid resolution is equal to: 4 Design Units
Design file has no schematics
Converting Unreferenced Symbols from Design libraries
Writing D:\ULTRALIBRARIAN\LIBRARY\EXPORTED\ORCAD\2016-05-23_14-34-34\2016-05-23_14-34-34.INI file
Library D:\ULTRALIBRARIAN\LIBRARY\EXPORTED\ORCAD\2016-05-23_14-34-34\2016-05-23_14-34-34.OLB is being saved
ADVICE: If you DON'T LIKE the result:
Do another orcadwrite run using one of the following sets of OrCAD writer options:
'Min pin to pin spacing'=2.54000 mm(s), 'Grid'=10000 design unit(s),
results in 0 hotspots out of grid
'Min pin to pin spacing'=1.27000 mm(s), 'Grid'=5000 design unit(s),
'Min pin to pin spacing'=0.63500 mm(s), 'Grid'=2500 design unit(s),
'Min pin to pin spacing'=0.50800 mm(s), 'Grid'=2000 design unit(s),
'Min pin to pin spacing'=0.31750 mm(s), 'Grid'=1250 design unit(s),
Finished on Mon May 23 14:49:56 2016
182 errors detected, 0 warnings detected
U?A
U?A
U?A
U?A
RM4
RM46
RM46L
RM46L8
RM46L85
RM46L852
RM46L852_
RM46L852_P
RM46L852_PG
RM46L852_PGE
RM46L852_PGE_
RM46L852_PGE_1
RM46L852_PGE_14
RM46L852_PGE_144
RM46L852_PGE_144
RM4
RM46
RM46L
RM46L8
RM46L85
RM46L852
RM46L852_
RM46L852_P
RM46L852_PG
RM46L852_PGE
RM46L852_PGE_
RM46L852_PGE_1
RM46L852_PGE_14
RM46L852_PGE_144
RM46L852_PGE_144
U?A
U?A
U?A
U?A
RM4
RM46
RM46L
RM46L8
RM46L85
RM46L852
RM46L852_
RM46L852_P
RM46L852_PG
RM46L852_PGE
RM46L852_PGE_
RM46L852_PGE_1
RM46L852_PGE_14
RM46L852_PGE_144
RM46L852_PGE_144
RM4
RM46
RM46L
RM46L8
RM46L85
RM46L852
RM46L852_
RM46L852_P
RM46L852_PG
RM46L852_PGE
RM46L852_PGE_
RM46L852_PGE_1
RM46L852_PGE_14
RM46L852_PGE_144
RM46L852_PGE_144
U?A
U?A
U?A
U?A
RM4
RM46
RM46L
RM46L8
RM46L85
RM46L852
RM46L852_
RM46L852_P
RM46L852_PG
RM46L852_PGE
RM46L852_PGE_
RM46L852_PGE_1
RM46L852_PGE_14
RM46L852_PGE_144
RM46L852_PGE_144
RM4
RM46
RM46L
RM46L8
RM46L85
RM46L852
RM46L852_
RM46L852_P
RM46L852_PG
RM46L852_PGE
RM46L852_PGE_
RM46L852_PGE_1
RM46L852_PGE_14
RM46L852_PGE_144
RM46L852_PGE_144
http://webench.ti.com/cad/cad.cgi
